Drivetrain Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!
Old 02-17-2015, 01:03 PM
Roxspin72's Avatar
Roxspin72
Roxspin72 is offline
Cerenkov,
You must be having a snow day also. Keep beating me to the post, LOL.
Hope your tune is running well. Can't wait to spray my 500cc nozzle once my tank comes in from Howerton.
Laters...
  #1577
Old 02-17-2015, 01:05 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Originally Posted by roxspin72
... Only go for stage ii plus if you are planning to run meth or have easy access and can afford race fuel. Not worth the risk.
+1
  #1578
Old 02-17-2015, 03:05 PM
Mcgee357's Avatar
Mcgee357
Mcgee357 is offline
Do you guys run the ngk 1422 iridium plugs or platinum when you go to stage 2?
  #1579
Old 02-17-2015, 03:14 PM
MarioKart's Avatar
MarioKart
MarioKart is offline
Vendor
I run them and haven't missed a beat, even at 28psi
mQubed Motorsport, Manic Tuning Dealer
  #1580
Old 02-17-2015, 04:24 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
I do too, and no issues either but I don't push it that hard.
  #1581
Old 02-17-2015, 04:58 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Because our tanks are a saddle type configuration, how much of a concern is there with proper mixing and uniformity of the fuel?
For example say that I start with 3 gallons of pump gas in the tank then I add 5 gallons of race gas. Will it mix properly or is it possible to have one side of race gas and one side of pump gas which could have unwanted results if I'm running a map that requires the good stuff.
I was always concerned about this when I was using Torco. The Torco can was only 32 ounces so I always added to an nearly empty tank while at the gas station then proceeded to fill up completely to hopefully mix everything up.
  #1582
Old 02-17-2015, 05:39 PM
minivinnie92's Avatar
minivinnie92
minivinnie92 is offline
I went two plus with just an intake and dp but I have the meth ready to b installed just to lazy and to cold and the laziness is directly related to the cold lol
Also I would think as the gas is dumped into the tank they would mix just fine if they stayed seperated than that means there is a high spot in the tank and if that's the case than when you got really low on fuel you would still have fuel on one side of the tank you can't use?
Also I'm sure driving down the street turning and everything else it will mix pretty good
  #1583
Old 02-18-2015, 05:51 AM
Grizld700's Avatar
Grizld700
Grizld700 is offline
It sounds silly, but when I mix gas I go and find a parking lot that fairly empty and start doing slaloms. After a few runs I drive off before I draw too much attention to myself.
  #1584
Old 02-18-2015, 12:08 PM
Gearheadaddy's Avatar
Gearheadaddy
Gearheadaddy is offline
Me too..lol
  #1585
Old 02-18-2015, 04:06 PM
minivinnie92
Lmao that's great and a good idea haha
  #1586
Old 02-18-2015, 05:04 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Not silly, I'm actually wondering if I should do this.
  #1587
Old 02-18-2015, 05:44 PM
Tigger2011's Avatar
Tigger2011
Tigger2011 is offline
Alliance Member
Go fast, turn left. Go fast, turn right. It's what these cars were born to do. I'll just add this one to my list of other reasons to do it lol.
  #1588
Old 02-18-2015, 06:06 PM
TazMinianDevil's Avatar
TazMinianDevil
TazMinianDevil is offline
This is also helpful to locate any items that might have been dropped under the seat.
  #1589
Old 02-19-2015, 06:28 AM
Grizld700's Avatar
Grizld700
Very true! But hopefully they don't find their way under the brake pedal!
  #1590
Old 02-19-2015, 10:34 AM
minivinnie92
That happened once in an old Mazda with all weather floor mats very scary
  #1591
Old 02-21-2015, 05:22 PM
sbninja's Avatar
sbninja
sbninja is offline
Been driving back and forth to work in Map A (stage 2+) really enjoying the power!
I recently installed a snow performance safe injection with a flow gauge. Nice to see in real time that my meth injection is flowing - not just hearing the solenoid open and the pump running.
I installed a 504ml/min nozzle but seem to be flowing more, as much as 780+ml/min.
I ordered a 441 ml/min nozzle. Adjusting the pump pressure too should bring closer to 500ml/min.
  #1592
Old 02-21-2015, 06:14 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
That gauge is cool.
Have you verified the accuracy? One way would be to spray into a bottle for a minute and measure the weight.
  #1593
Old 02-21-2015, 06:15 PM
wzabrouski's Avatar
wzabrouski
wzabrouski is offline
That seemed like a lot of cc's.
  #1594
Old 02-21-2015, 07:14 PM
sbninja's Avatar
sbninja
sbninja is offline
haven't checked for accuracy, but I will when it get a bit warmer out. According to the nozzle website, the 504ml/min will flow at a higher rate with higher pump pressure.
I will adjust pump pressure more, and see. If I have to, I will switch to the lower flow rate nozzle.
  #1595
Old 02-21-2015, 08:19 PM
minivinnie92
What did you pay for your methanol kit and how do you like it?
  #1596
Old 02-21-2015, 08:23 PM
Roxspin72's Avatar
Roxspin72
This looks awesome. Did you already have a Snow Performance setup and then added this? Also, did you do just the gauge, or did you install the the whole SI system? I see that they are sold separately. Wondering how hard it would be to run inline w/my current Snow Performance Stage II setup...
Any info would be helpful.
Thanks...
  #1597
Old 02-22-2015, 06:24 AM
sbninja's Avatar
sbninja
sbninja is offline
I paid $370.00 last year.- snow performance boost cooler kit 20010.
I like it. I just needed to get longer tubing and some electrical wiring because I installed it in the trunk. You would need to come up with a way to mount it.
I bought the snow performance safe injection and the flow gauge to add to my snow performance kit (20010) the guage will only work when connected to the safe injection.
The safe injection installs easily inline (tubing). And wiring connects to boost controller and guage.
Yeah, the gauge is cool. You can choos blue or red light
  #1598
Old 02-22-2015, 06:32 AM
sbninja's Avatar
sbninja
sbninja is offline
Here is the install in the trunk, I got a piece of black lexan to mount the tank, solenoid valve and pump.
<CALayer: 0x14e70f40>
Attached Thumbnails Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!-image-151750777.jpg
  #1599
Old 02-22-2015, 11:03 AM
sbninja's Avatar
sbninja
sbninja is offline
I just got back from a test ride. I turned down the pressure on my pump a few times, now I'm flowing right around 500ml/min I guess I don't need to install the 441ml/min nozzle. I also ordered a 1 gal fuel cell from summit racing. The Snow Performance kit comes with a 3 quart tank. The 1gal tank would last a bit longer. Plus it has a separate vent fitting. Sent from my iPhone using NAMotoring
  #1600
Old 02-22-2015, 04:39 PM
wzabrouski's Avatar
wzabrouski
Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!-image-1968170809.jpg
Still love how my setup is hidden below the deck.
Quick Reply: Drivetrain Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!
