Drivetrain Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!
#1776
I agree but it seemed like a lot of meth for map B. 500cc per min is what was recommended for map C from Manic.
#1777
The 500cc is not constant, so the more boost= more cylinder wall pressure, so that 500cc maybe go down to 450cc when driving just one map higher mQubed Motorsport, Manic Tuning Dealer
#1778
on
441cc/Min. A bit less than the recommended 500cc, but I like the nozzle Technology, and unfortunately this is the closest I could find to 500cc.
This Nozzle paired with the DO Check Valve and Low pro Nozzle holder, is working out sweet!
Today using Map C:
Ambient was 68... I was tracking 43deg IAT/11.5 AFR/10-12 +deg timing and climbing... Awesome power through all the gears. Need to get out to some nice open roads and Log
#1780
on
Not sure if there is any such thing as too Low of IATs... But I do know the cooler the temps, the more timing and boost available, within a safe AFR.
But so far my Tune is loving the new Nozzle. All hooked up, and no Leaks, I'm one happy Modder.
#1781
I'm using the Devils Own Micro Droplet Nozzle (DO7) 441cc/Min. A bit less than the recommended 500cc, but I like the nozzle Technology, and unfortunately this is the closest I could find to 500cc. This Nozzle paired with the DO Check Valve and Low pro Nozzle holder, is working out sweet! Today using Map C: Ambient was 68... I was tracking 43deg IAT/11.5 AFR/10-12 +deg timing and climbing... Awesome power through all the gears. Need to get out to some nice open roads and Log
#1783
#1784
Too bad your not in law enforcement. You could have put it on your cruiser... or a buddies hehehe
#1786
#1787
After you spend all your money on every bolt on for your Mini, the Tune lets you take full advantage of all the parts you spent time installing. I drive my GP on Map B 90% of the time and switching to stock, makes you realize how slow the car is with out the tune. I drive my Mini extremely hard every day, 7 days a week and it's the ultimate stress reliever. It's mobile therapy My own Big Valve Head is going to shock the V8 guys out there. My poor tires will be short lived mQubed Motorsport, Manic Tuning Dealer
#1788
My own Big Valve Head is going to shock the V8 guys out there. My poor tires and short lived
#1789
After you spend all your money on every bolt on for your Mini, the Tune lets you take full advantage of all the parts you spent time installing. I drive my GP on Map B 90% of the time and switching to stock, makes you realize how slow the car is with out the tune. I drive my Mini extremely hard every day, 7 days a week and it's the ultimate stress reliever. It's mobile therapy My own Big Valve Head is going to shock the V8 guys out there. My poor tires and short lived mQubed Motorsport, Manic Tuning Dealer
Map B is Awesome! Though probably not as awesome as you GP.
Don't worry I will order my bigger turbo from you soon enough!
#1790
#1791
#1792
I'm a little late to the party, but I had a Manic Stg 2 tune installed on my 2013 JCW yesterday and wow what a difference! I also had the WMW catless DP and a Forge FMIC installed at the same time so I'm sure that helped with the jump in power, but it feels like a whole new car. If anyone is on the fence about the tune like I was for a while, don't hesitate to take the plunge. It's pretty awesome!
#1793
#1794
#1795
on
However I am an advocate for Meth on Map B. If you monitor your temps and all, the tune is just happier with higher octane and cooler temps both B & C. If you can't, IMHO: I would stay away from Map B whenever over 80deg ambient plus don't forget humidity factor..👍
#1796
#1797
#1798
Yep. I have been chasing what the ECU is a boost leak but it is the wastegate bushing not operating properly, which is not allowing boost to reach target.
#1800
