Drivetrain NEVER put on AEM Turbo Heatshield, EVER
#51
#53
Melted at the track https://www.northamericanmotoring.co...lve-cover.html
Just melted https://www.northamericanmotoring.co...eatshield.html
#54
#55
#58
#59
Wanted to update this thread. I have been keeping an eye on my NM shield after seeing this post. Well it's starting to heat up here in SoCal and guess what? Valve cover is already starting to warp in the exact same spot as ra2fanatic's. So I pulled it off this morning. It's for sale in the marketplace if anyone wants to risk it...
#60
I just read this thread and I'm glad I did. I ordered the M7 heatshield that's been on back order for a couple of weeks. now I'm thinking I should cancel my order and hope nothing happens to my hood scoop in the long run with the heat from the turbo and so on.
geez... you think you're doing good by buying a heatshield to prevent heat damage (as in the hood scoop) and then u realize you're F'ed in other places.
#61
#62
I've had the M7 shield on my JCW for two hot SC Summers, with no problems. The M7 seals against the head, just below the cam cover, which prevents turbo-heated air from blasting the plastic cover. That said...Due to the problems some have had, I removed it and installed the WMW wrap a couple of weeks ago. Unfortunately, the hood still gets too hot to touch with the wrap installed!? So today (or, as soon as I finish the valve cleaning...aarrggh) I'm going to re-install the M7..with the wrap.
Jon in SC
Jon in SC
#63
Jon in SC
Jon in SC
#64
M7 is not okay. If anything the M7 was the first heat shield with a reported issue causing valve cover warpage. There was a huge thread and M7 did not own up to the design flaw. I you're going to wrap the turbo I'd say wrap it and leave it at that. Let that bit of heat travel up and not off the sides of a heat shield that can potentially cause further damage.
#68
Yea I was skeptical when I bought it, just thought it made the engine look really clean and it might help with hood heat. I still think my hood was just as hot though...
#69
In terms of just keeping the hood cooler, install the factory heat shield over the rear of the scoop -
http://www.outmotoring.com/mini-coop...at_shield.html
Its just a thin shape of metal, some minor cutting is needed to make it fit the later Gen 2 cars, but it works quite well..
You can also install some of this on the underside of the hood - http://www.designengineering.com/cat...s/reflect-cool
That stuff works very, very well.. and really keeps things from getting cooked.. like stripes and scoops.
#71
#72
did just that and my hood dropped 30 degrees
#73
Ugh!!! My turbo inlet tube just broke so I figured it would be a good time to upgrade the intake. I've got the AEM on order but this thread has scared the hell out of me :-(
My concern now is if I take the turbo shield off, it's going to warp or melt the scoop intake...
I live in Phoenix, AZ, and temps are 110+ all summer long. The reflect-a-cool lining seems like a good idea, I just don't think it will be enough :-(
Thoughts?
Thoughts?
#74
#75
