Drivetrain NEVER put on AEM Turbo Heatshield, EVER
#79
Intake gets here tomorrow! Definitely going to have to go the ceramic coating route at some point...but I ordered a hood scoop heat shield from WMW for now. It's cheap ($30) and it looks like it will block a good portion of the Air duct from the scoop. Guess we'll see how it works this summer when it hits 118 :-\
Link to the scoop heat shield
http://www.waymotorworks.com/mini-co...5-r56-r57.html
#81
I'd agree with you...if I weren't in phoenix. It's common for it to be 115+ for a week at a time during the summer. Its decimated the plastic under the hood. Nearly every clip on the ecu wiring harness had melded together or warped so badly they broke when touched. Hell, even the battery cover clips (And hinges) became so brittle they snapped off with almost no pressure applied. I'm taking precautions. Not EVER putting the EAM heat shield on.
#83
This was AEM heatshield and stock turbo heatshield on. The idea being the AEM assisted in keeping heat away from the top of the engine and intake area. And it did. Too well in fact it, it trapped all the heat right at the valve cover.
#84
NM Heat Shield: After 10 Months
This thread put the fear of "hell fire" into me. I just removed my NM Engineeing heat shield wondering what I'd find. There were no signs of any heat-related damage (warping, melring). That being said, I've removed it just in case.
I've attached some photos of the engine with the shield removed and of the underside of the shield. Really, all looks fine.
~ Alan
~ Alan
#85
So is the consensus her to either use a turbo wrap and / or have turbo, DP etc ceramic coated and just ditch the AEM heat shield?
I installed the AEM intake/heat shield about 2 months ago and would like to avoid any of these issues...
Can you run a turbo wrap and heat shield or would that still be trapping too much heat? I like the way the engine bay looks with the shield installed.
#87
I have the AEM heat shield on and trimmed to only cover the hot side of the turbo. The rear portion of the factory heat shield is on and the top of it is cut so that the AEM shield is sitting on the cut I made. (This way there is no space between the two heat shields. I think I had to cut some of the AEM spacers to achieve this fitment.) I also had the turbo wrap on. I recently took the wrap off and found what appears to be surface rust on the turbo and haven'n re-installed it.
I believe ceramic coating is in the future for me.
#88
#92
#93
#94
Turbo heat shields are just an eye candy, that on occasion, result in melted valve covers.
a
#95
I used this product on mine. it took me about 1-1.5 hours to install.
http://thermotec.shptron.com/p/turbo-cover
#96
If there's some way to block the hot air from coming across the corner off the valve cover it'll be ok. However, the only time I had an issue is when the down pipe came lose (after 136,000 miles) the hot air could only escape frome the open corner in the shields. It's was because the down pipe came lose. Not from normal heat dissipation. I had all the shields on, AEM kit heat shield on, lost the intake boost tube to the cooler. Turbine side was ripping red hot. Still didn't melt or wrap anything. Downpipe comes off, your screwed. It's melting that valve cover no matter what heat shields are on. I melted TWO in 1 day before I realized the downpipe was loose Personally, I run them all. Sorry about the past response.
#97
#98
#99
