Drivetrain Catalytic converter and emissions
If i was to remove my catalytic converter i know the ecu will throw a code obviously but i wanted to see if those extension bungs eliminate the check engine light, my main concern is emissions here in NY. They plug the car in for emissions (no longer with the smog probe etc..)
So will the o2 extension bung eliminate the CEL ?
OR
Is there something else that can be done ?
Also if you have any tips or advice from personal experience please let me get your 2 cents...thanks.
OR
OR
OR
i recently was running just a test pipe with my new header. it was obnoxious. the magnaflow high flow cat gives it a nicer tone and wont cause a cel.
Ian, I dont care about the legality and i dont care about drone. It wont be a daily driver BUT i will be driving it around a couple days during the week. My main concern is emissions when it comes time to inspect and when the car is plugged in i dont want it to show a rear o2 fail. I know i can use the 90* o2 like this:
http://www.ebay.com/itm/1x-O2-Oxygen...-/331127313934
Again loudness/drone isnt a problem for me, my last car made 718hp and had a straight pipe (no resonators/muffler) and an external wastegate dumping out the side bumper so yea... heh.
https://www.outmotoring.com/mini-cat...or-spacer.html
i think this would solve the issue, ill be doing the same thing of going catless, but if my tune cannot code out the CEL ill have to be innovative. possibly with the thing above. I already have a magnaflow highflow cat just incase i dont enjoy the sound
NY doesn't test "emissions", technically speaking. If they did, all catless cars would fail.
With a functioning O2 simulator, whether it be electrical or mechanical, you will pass OBDII diagnostics just fine. The best mechanical O2 simulator I've used thus far is made by Vibrant, and it comes with 3 different inserts, as to allow for adjustment of restriction to the O2 sensor. This allows you to fine tune the simulator if one size still results in a P0420 code.
you could get a high flow cat from magnaflow for a few bucks more than that spacer on outmotoring.
then you have 100% no light.
i dont have the dyno to prove it, but if you do some reading online, 9 times out of 10, youre looking at a gain of like 2hp going catless.
to each their own. i ran my car catless for a few months. then emissions time came and i had to either pay to get my stock cat welded back in, or buy a high flow cat anyway.
the magnaflow model that fits our cars has a 2.5 in/out. im pretty sure it was like ~$65 on amazon.
again, im not saying youre wrong for going catless. you just have to ask yourself if 2hp is worth the headache of the cel when youll most likely have to swap out the test pipe everytime emissions is due. just giving advice based on my experience. hope whatever you decide on works out.
my mistake on the price. it is actually about $80. hope that wont change your mind. and i dont work for magnaflow or anything lol. its just the one that i have and that a lot of people recommend.
http://www.amazon.com/gp/aw/d/B000COTIRK
also if youre replacing the cat back piping with 2.5, you should consider at least doing the one ball mod (removing the resonator and replacing with 2.5 piping to the muffler), unless youre replacing the muffler as well. my cuurent setup is: megan race header, into 2.5 magnaflow cat, into 2.5 piping routed passenger side of the battery, into a tiny little cherry bomb muffler (which is like 10"x10" and cost around $45 with 2.5 in/out), out the back of the car with a 5" tip.
Not bad at all....Jown, I'll be making my own exhaust out of 2.5" titanium but if i do end up getting this car im going to have to weld 2 vband flanges onto it AND 2 vband flanges on my exhaust...if i go that route then i might just make a test pipe and weld 2 vband flanges on that as well and when inspection time comes around ill just swap in the cat...
This is of course if the o2 trick doesnt work then ill be going that route.
im rocking the P0420 code now too :(
its funny, i had my o2 unplugged for a week or more waiting to get my exhaust finished (driving with open headers) and NO cel light... get exhaust installed, slap in o2, and a week later, BAM! cel light!
im half tempted to just unplug the damn thing from the exhaust, zip tie it somewhere, and use a bung plug, see if she throws a code. otherwise, im going to try and drill out 2 spark plug defoulers, stack them to be used as the o2 spacer.
there is an electrical o2 simulator for minis, but its like $40, just an FYI...
I have been running the Magna Flow cat for several years, Don't let anyone fool you after a little age it will throw the 420 code. I don't have smog testing so it doesn't bother me. I just reset it and it may stay off for a week or it may stay off for a hour. I plan to play around with depth of the 02 sensor it the pipe, Some of the supercharged Cobalt guys have the same problem and that is how they over come the problem.
09-04-2015 12:20 PM
