Drivetrain JCW intake and Exhaust VS aftermarket
I have a question guys. I have a 2008 Mini Cooper S with the JCW package from the dealer. Would it be beneficial (more HP) to change the JCW intake and exhaust for aftermarket. I like the looks of the AEM intake and there are several decent exhaust out there....but could I expect much difference compare to the JCW? Thanks in advance
In my opinion, the JCW Tuning kit airbox is the best intake available for the MINI. It's why I installed it on mine. As for exhaust, you will see some improvement by replacing the exhaust with a DP-back unit, since it eliminates an un-used cat. However, the biggest improvement will come from replacing the downpipe itself. Even keeping the tuning kit exhaust you'll see far greater improvement then just replacing the exhaust.
Thanks for the info. Will eliminating the un-used cat cause a CEL? Pass inspection?
Don't waste money on a magnaflow or some other cheap exhaust alternatives. Too much drone if your ears can't handle it on the highway.
Not to deviate from the OP, but do you know if it is the same air intake that came stock on an '09 JCW? If I remember right there was an upgrade available for the JCW as well in '09 but mine has the stock one. Wasn't sure if going aftermarket would be worth it compared to getting a FMIC and tune.
07-16-2020 12:54 PM
01-04-2019 12:51 PM
08-12-2015 01:24 PM
08-11-2015 11:58 AM
jrezzo
08-09-2015 10:32 PM
