Drivetrain 12mm to 14mm lugs--- drill ???
I got a good deal on a used set of Advan wheels but the bolt holes are for the 12mm.... mine is an 07 with 14mm ....
As I stand over the wheel with drill in hand I figure I would ask around first..hehe
I'm still hunting down some hub rings...( wanted to punch the guy at vivid racing over the phone.. what an *** )
I mic my boar at 61.7 so I was thinking 61.5 would work.... hard to find in aluminum seams like... needing 61.5 x 56.1
Anyway--- anyone else drilled your 12mm bolt holes out to 14mm ???
yeah you will lose some taper but the Advan wheel tapper looks to be long..will mic those next
I'm all for doing things yourself...but I wouldn't recommend it without using a drill guide to ensure your perpendicular to the hub flange. You also need a 14mm reamer with a 12mm pilot on it. Otherwise tooling marks in the bolt holes will create stress risers and cracks will propagate from there.
In aviation I find cracked aluminum rims more often then I'd like and it's usually a tool mark or casting imperfection that is the root cause.
I tell everyone to run these....
http://www.waymotorworks.com/m14-to-...rsion-kit.html
Add some regular conical nuts and call it a day. You'll be able to run M12 or M14 however you like! :D
You can get an aligning reamer from Wholesale Tools and ream (NOT drill) the rims and use Gorilla Bolts. I get them from Discount Tire. Adapter rings are available there as well. The Gorilla Bolts heads are the same size for 12mm and 14mm threads diameters. The reamer runs about $18. It's a combination tapered reamer transitioning to a straight and is also called a car or construction reamer. The holes in the wheel are larger than 12mm and 14mm.
I understand on the conversion kit, I even looked at them. I just don't like going backwards ...
I drilled out the wheels on my sandrail but it has balloon type tires on it. I jump it and abuse it and never had an issue
I also drilled out my 10.5 drag car that I launched on NOS. Never saw a crack but after a few weekends to the track I stopped looking as hard.
I was going to chuck the wheels up in the drill press or buddies mill but I kind of feel like a good angle drill bit ( say 90 deg instead of 118 deg ) will keep it self centered . If you chuck it up in a drill press and your off it will just be off centered. With a free hand drill with a bubble level mounted on the back of the drill so you can keep it centered and your drill bit can help keep it centered you should be fine. Remember the tapper of the lug nut / bolt is what centers the wheel . As far as machine marks causing cracks , I could polish up the holes after with a carter key chucked up in the drill and some emery cloth flapping around
As of right now I'm still in "think" mode the stud conversion kit is nice but you guys are talking about load and they did step up the lugs size for a reason. More people are pushing these cars so better get those wheels to stay on...lol
http://www.evasivemotorsports.com/mm...HEELMATE-STUDS
Just saw this, but like they all said using the stud conversion kit is much easier and better than drilling some wheels.
funny.....
you guys act like drilling out the wheels is a major error...
yes I agree the stud kit might be the best way to do this ( if your cool with smaller studs ) But the face of the rim is held pressed to the rotor by means of the lugs ,,,
the lugs are 60 deg tapper to center the wheel ..
.. not the holes in the wheel.....
hub rings aid in centering the wheel .
drilling isn't a big issue.
I did it on the previous set of wheels I had, my CE28 where drilled to fit M14 stud kit, but knowing that these are Advans that you don't see very often, it might behoove you to not redrill you know.
Some might not like the idea of redrilling some nice wheels if you got tired of them and decided to sell them. In my case, it seems I keep changing wheels every 6 months, so someone will likely lowball me because I redrill, I save myself that headache by just running the conversion kit =P
The other thing that is nice about the conversion kit is that you get studs, not the bolts that the factory uses.
I agree on several points:
1. drilling holes will be used against you if you ever sell the wheels.
2. It is the tapers on the lugs that secure the wheels, not the bores for the studs.
3. Drilling could be done, but make sure that there are no stress risers that can result in cracks or future problems.
Have fun,
Mike
Have fun,
Mike
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
Tires, Wheels & Brakes
10-01-2015 02:22 PM
10-01-2015 10:38 AM
