Drivetrain Wavetrac
Wavetrac
Has anyone installed the Wavetrac LSD? Technically, it seems to me the Wavetrac is a bit better as the Quaife.
http://www.wavetrac.net/news.htm
First i have installed the quaife, but after less than a year I had loud noises. This was then sent to Quaife and replaced me after more than 5 months. Good customer service looks different. Since I did not want to wait so long, I have installed the Wavetrac. The Wavetrac is much better as the Quaife. Even after more than a year no problem. The response is much better. She also works in the wet, which was a problem with the Quaife. On icy ground the Quaife eg does not work at all.
For the street Wavetrac is clearly the better. In addition, it also works better on the track. But clearly for the pure track use, I would rather fit an LSD. An ATB (Quaife, Wavetrac, ...) do not function during braking. A ATB does not lock like a LSD, but shifts the torque. However, LSD is subject to a certain wear. Also must be replaced annually, the transmission oil. These are two important points that unfortunately many forget.
09-16-2015 02:01 PM
09-16-2015 01:59 PM
Euler-Spiral
07-19-2015 10:23 AM
