Drivetrain side exit exhaust
side exit exhaust
mods, please move this to the correct place because im not sure where it'd go....sorry
but i was thinking the other day, since I love straight drag and v8s... and all that fun stuff... every turbo small block has the exhaust coming straight out of the fender. I personally love this because imagine how loud the turbo spool would be on hard acceleration and if it's straight-piped the flames popping.
has anyone every done this? i would totally love this. but looking under the hood i cant imagine how it would be done. maybe a lower side exit?
could someone post some pictures of their setup if they have this? i would love to know more if it's been done!
Here: MCS Side Exit
Seen a R53 from CT with a side exit just like this....It sounded way better than anyone could have imagined. Was no where as obnoxious as the Magnaflow I had by any means.
Unless you're willing to lose a bunch of ground clearance side-exits from underneath the car aren't really feasible unless you're using ovalized piping which is expensive and difficult to work with. Unfortunately the engine bay in the mini is pretty cramped and the wheel well set back from the engine bay so it'd be really really difficult to make it work. With enough cutting and welding new metal though....
It looks like the guy in the video was able to wrap the exhaust around the back of the fuel tanks and poke it out the rocker without dropping the exhaust under the car (killing ground clearance). I can't see whether he put heat shielding between the exhaust pipe and the plastic fuel tank--something that would probably be a good idea. Tuning the sound of the exhaust would be very limiting, since you would have do to all of the resonating/muffling in the tunnel. If you poke it out the rocker, I would fit a piece of sheet metal on the outside of the rocker to shield the plastic from the hot exhaust gasses.
The link has a great photo of pipe routing that shows the best route without loosing ground clearance e.g.,
Overall I think it is nice work, I would like the sound to be just a little deeper, maybe using a slightly wider ID pipe... But nice job and I would cap the pipe ends with the JCW tips.
I would also add some heat shielding above the pipes, I wouldn't want to accidentally add a heater to the fuel cell...
Motor on!
Motor on!
man... id love to get another mini just to do a project like this. maybe a turbo with the exhaust coming just out of that little panel behind the hood. I'd have to move some stuff around, sure but i think that'd be cool... maybe just for like a street rod mini or something for the car shows. used minis are like, under 6 for an older one, but it'd have to be turbo to get that flame shot. i was just curious if anyone had ever done it as a custom build or something.
This is one of the best ways to kill what little power these cars have!!! 90 degree bends work wonders at choking exhaust gas passage. This will make your MINI sound very nasty when you're in line at the drive thru and also earn you a ticket because it is against the law to exit gases next to a passenger compartment. Why not get a 1/2 set of ZOOMIES from back in the day and an exhaust cutout from jcwhitney you'll be stylin.
ISAMIN
ISAMIN
ISAMIN
ISAMIN
07-16-2020 12:54 PM
Gil-galad
Eastern Iowa MINIs
63
11-17-2016 02:54 PM
ltjpunk7
09-06-2015 07:32 AM
cm.d
08-19-2015 08:51 AM
