Drivetrain Turbo difference between Cooper S and JCW
Old 01-21-2016 | 06:04 AM
Tweedbean's Avatar
Tweedbean
Been doing a bit of investigation and wondered if anyone could help. It would seem that the US Cooper S, US JCW and UK JCW share the same turbo while the UK Cooper S has something different, see part numbers below
RealOEM - Engine - country - Model - Prod Month - Turbo part number - Injectors part number
F56 B46 US Cooper S 09/2015 11658626637 13537639990
F56 B48 Britain Cooper S 09/2015 11658626636 13537639990
F56 B46 US JCW 09/2015 11658626637 13537639990
F56 B48 Britain JCW 09/2015 11658626637 13537639990
Any idea what's the next step to find out what the difference are between the two part numbers and if its worth upgrading a UK Cooper S to a JCW turbo?
Old 01-21-2016 | 02:01 PM
vetsvette's Avatar
vetsvette
Moderator
I had read that the S and JCW turbos were the same, but wasn't aware of the UK thing. Could be a typo. Don't know of a way to check the specs.
Old 01-21-2016 | 03:20 PM
Same on US side. Might have different parts number due to regulations or the ECU they are using , best way is to order up in the uk side and put them side by side. Measure the turbo and inlets. Dealership should help you over there. Also look at the name plate and cross ref the numbers.
Old 08-28-2018 | 07:48 AM
boki's Avatar
boki
Sorry for resurrecting this thread from dead but do we now the specific specs on both turbo's? I thought I read somewhere that the compressor wheel on the JCW turbo is like 2-3mm larger? This is the only thread that came up when I searched here that has this in the name of the thread.
Old 08-28-2018 | 11:14 AM
MrGrumpy's Avatar
MrGrumpy
The turbos for the R-series are different. The Cooper S turbo has a 37mm compressor and the JCW has a 40mm compressor. It appears that the newer F-series share the same turbo with the JCW.
Old 08-31-2018 | 07:17 AM
boki's Avatar
boki
Hmmm, so all they did for F56 JCW is install stronger and lower compression pistons and cranked up the boost a little? I was expecting bigger differences, how about the rods?
Old 09-12-2018 | 01:06 AM
Clutch Wotan's Avatar
Clutch Wotan
MINI does not tune like you expect, the lower compression 1:10 versus 1:11 is one part, the other part is a complete unique cooling system which guarantees the that the boost works !
Old 09-17-2018 | 07:54 AM
boki's Avatar
boki
Is the JCW's intercooler that much bigger/flows better that it's going to be a huge factor in the performance differences? And you are talking about that little side/fog lamp cooler that JCW's have? They still use the same turbo for JCW as in Cooper S, right? So that means that they have to up the boost somewhat to get that extra hp, right? Lower compression will prevent some pre-detonation so more power could be pushed out of it, right? I was wandering about those aftermarket pistons that just came for the F56 platform (https://www.lohen.co.uk/supertech-mi...r-cooper-s-jcw) - is it better for me as a F56 Cooper S owner to get aftermarket JCW pistons with the lower compression of 1:10.2 instead of 1:11 and have aftermarket tune that pumps up more boost or stay with standard Cooper S aftermarket pistons and don't push it too much. Assuming I install an aftermarket intercooler that would cool the intake air somewhat better than the stock on consecutive pulls (oil cooler can't be fitted unless the whole front bumper is swapped and I don't want to do that, and even then not sure if it's doable). If the pistons are the only thing other than extra cooling that separates Cooper S and JCW than getting JCW aftermarket pistons with lower compression could be a way to get a bit more performance out of the F56 Cooper S then. Are they both using the same rods?
Old 09-17-2018 | 11:02 AM
Clutch Wotan
The connecting rods are the same, you can buy OE JCW pistons
11 25 8 638 450
€192.92
a set of forged pistons from Mahle is around 1000 Euro, the BMW piston kit includes the pins, also you should consider than 9.5 if you customise them anyhow.
As the intercooler from JCW is bigger the actual radiator is smaller and get compensated with remote, so the Cooper S radiator is bigger (Height) and a aftermarket intercooler useful.
Old 09-17-2018 | 02:55 PM
boki's Avatar
boki
^Thanks for clarification. Yea, a friend of mine has his JCW at the dealership with a misfire issue that they are trying to fix for two weeks now and there might be an issue with the engine that would require the engine rebuild. Now, he does have down pipe and full exhaust, cai, ic and a certain stage 2 tune (he returned the stock tune before bringing it in for service) so they might not cover the repair. So that got me thinking that even stronger JCW pistons might not be up to task of handling stage 2 tunes, that's why I was considering getting aftermarket, even stronger pistons. But that's all in the future, I'm not going to modify my car much until the warranty expires anyways, just collecting information for now.
Old 09-18-2018 | 03:07 AM
Clutch Wotan
Thats ok - MINI parts are expensive, the warranty should be always considered ;-)
I can only say that a f56 with 300hp scoots, and my turbo is the same as on the Cooper S and JCW
Old 09-19-2018 | 09:26 PM
charrigan's Avatar
charrigan
I'm going to take a wild guess and say it's a bytetronik tune....
Old 09-20-2018 | 07:40 AM
bratling's Avatar
bratling
Super Moderator
Question
…meaning?
Old 09-20-2018 | 07:41 AM
boki's Avatar
boki
And you'd be wrong...I'm not saying anything else because we don't have a proof the tune did it.
Tweedbean
07-08-2018 07:14 AM
audio131
01-18-2016 04:27 PM
BadakVT
12-04-2015 09:07 PM
KinetechMW
11-30-2015 09:34 PM
