Drivetrain Straight Pipe with Resonator Sound Clips?
Here's a video clip of my R53 with 2.5in piping and only one 18" vibrant resonator. It's definitely on the loud side, and does drone on the interstate with the windows up, but its not unbearable.
2004 Mini Cooper R53 Custom Exhaust - YouTube
We'll find out. I just got a tune from RMW, so I'm wondering if back pressure is gonna mess things up which is why I'll keep my piping stock. I'll make sure I post a video once its done. Right now I need to get a gasket for the flange and then I'm looking around for some tips. Have you noticed any changes in performance or just more volume?
But most of your back pressure is held in the header and the cats... if you're running more boost and a tune I think you have more pressure that needs some relief.
The whole tip situation was hard for me too because theres not many that will fit behind the battery box. I used a Redtail Performance oval tip. It just barely clears.
I did it around the same time I did a WMW 16% pulley so I don't know how much gain was because of the exhaust. But I definitely noticed it pulled harder from about 4K to redline.
I got it done, but need to replace the tips and some piping cause the straight pipe work was terrible from the last own. Res was installed aright after the flange. I thin the low end torque is lessened a bit, high end may be there. If I put a muffler on it may be best. This is insanely loud lol. I'll try for video soon.
