Drivetrain 30 boost correct ?
30 boost correct ?
Hi
My scan gauge is saying that im getting 30 psi of boost at this point my car really starts to complain, I think im getting pre detonation sounds like rocks in the motor and engine starts cutting out.
Im wondering if im actually building that much boost or are these not that accurate ?
the car has lv 2 tune ,one step colder plugs ,and 42 mm turbo with ebay intercooler and a diverter recirculator . 2007 S
thanks
thanks
My AP scanner has two different "Boost" readings, one for each MAP sensor. The MAP/T sensor reads absolute pressure --- atmosphere plus manifold. The manifold MAP sensor reads only manifold pressure / vacuum. Sounds like your reading of "30" is from the MAP/T sensor --- 14.7PSI (sea level) plus whatever your turbo is producing --- typically 15 - 16 PSI. Maybe browse your scanner for another boost source?
Drivetrain Schwaben tool - can it log boost,?
cyberlunacy
02-08-2021 12:41 PM
scottab36
03-10-2011 05:31 PM
