Drivetrain best OCC to use with AEM Intake and Strut Bar
Just bought an NM OCC, great piece of kit but the design simply does not fit with the AEM Intake (rubs against the plastic inlet pipe from the filter box) and especially with the Strutbar it makes it damn near impossible to unscrew the thing without taking the bar off and that’s just not going to work on a regular basis.
Anyone using an OCC with the AEM intake and Strut?
Alternatively, are there any other mounting points for an OCC in the N18 engine that I should consider?
Pain no? I got the NM unit because it’s baffled and I didn’t just want a cup to collect oil in lol. I got it to fit in the no specified location but man it’s a tight fit and I really don’t know if I could unscrew it. I didn’t finish the install just test fitted and didn’t use the firewall punch screw yet.
looks like maybe the BSH one is the best as you can mount it by the washer fluid tank. But if you’re installing a BOV like the forge unit that could be an issue as well.
Hmm
Hmm
it looks tight but right by the 90 degree bend in intake by the firewall.
Yeah I'm a sucker for pretty strut bars so that's not going anywhere. I can shove the NM one in there too, but the firewall mounting point hardware welded to the box makes it tougher.
What interests me is if the bsh units bottom drain vent can be used to drain the entire can because then unscrewing it isn't really an issue
oh definitely going to trim once i permanently install. the guys at NM got back and told me that they've seen them installed behind the driver headlight near the fresh air inlet. I'll give it a gander eventually, maybe install everything else if I can convince someone to lend me a carlift in nyc!
Went for a 200 mile drive, all's well.
I tried looking at the fresh air inlet and a smaller universal can could fit there but not this NM one. I'm gonna obviously keep this NM unit now but whenever I can head upstate to my parents (when it's safe!) I'll probably take an angle grinder to the firewall support. it's really not needed with how tight the thing is and I'll weld a few handles around it so I can more easily grab it and unscrew it
I cant post a picture right now but..
I have it on the same spot as all of you...I have a Saiku Mitchi OCC with AEM N18 intake+Aem strut bar.!
In order to empty it when you want and because i dont want to unscrew the whole OCC i put a manual "valve" with a silicone hose that goes under the car so when you need to empty it just open the valve and close it after it drains and you done!!!
a T Junction could work nicely though I'm wondering about gravity
I was hoping you would post a pic. I’m looking at strut bars, after brakes, the AEM was on the list but nope not anymore. All though it does look like it would still fit in the same spot, just would be up against the firewall.
https://www.ecstuning.com/b-genuine-...63122338554kt/
His is an NM power module
https://www.ecstuning.com/b-nm-engin...nm.648856~nme/
StillwaterMINI
Suspension
05-23-2010 04:19 PM
pfunk
Suspension
23
06-11-2003 06:14 AM
