Drivetrain Brake Help!!!!!!
Brake Help!!!!!!
I am trying to swap my front pads and am getting a little, ok a lot, pissed off. I got the old pads off and now I can't fit the caliper back on with the new pads. How do I get the piston to retract enough to make it fit? I tried turning on the car and hitting the brakes then tried to push the piston back in, it would budge. Your immediate help would be appreciated. Thank you!
The caliper won't go back on because the new pads are thicker, as I'm sure you've figured out. For the front brakes, you can use a c-clamp to push the piston back in a bit. Try to come up with an arrangement that pushes straight back on the piston. Before getting a specific tool to retract brake pistons, I used a c-clamp with a screwdriver perpendicular to the piston so the c-clamp would have something to push on that was centered.
If you've added any brake fluid, make sure the reservoir doesn't overflow as the piston gets pushed back in. Also, don't push the piston in further than necessary to get the caliper back on.
For the rear pistons, they will need to be turned as they are retracted. Don't just shove them straight back in like the fronts.
Good luck.
Scott
90STX
Good luck.
Scott
90STX
Originally Posted by gregsminis
Thank you so much! I don't have a C-clamp but I was able to get a 4ft bar clamp to do the trick. Ahhhh (sigh of relief).
Earl
It's also a real good idea to open the bleeder valve as compress the piston. This keeps the dirty fluid, which is typically sitting in the calipers, from travelling back up into the system. That old dirty fluid can do a lot of damage to the ABS modulator. Follow up the installation of the pads with a bleeding of the brakes to flush out that old fluid.
retracting the piston on a brake change
quick and clean fix. Purchase a simple steering wheel puller from a hardware or auto supply. Leave the inner old pad on the caliper and slide the puller inside the caliper.. Tighten the bolt and force the pistion in. Takes 30 seconds and no smashed knuckles and discourteous utterances.
This has been documented in my Brake Pad writeup.
https://www.northamericanmotoring.co...ight=brake+pad
As well as my Rear Pad writeup
Richard
Richard
Richard
Richard
Tinklespout
16
09-06-2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
09-03-2015 03:22 PM
