Drivetrain OBX-Racing Header Dyno Results!
#252
I basically know very little about aftermarket MINI parts, seeing as how I don't have a MINI yet, but I kinda need to chime in with my two cents, OBX products tend to be in the cheapo/budget range of parts for other cars, especially Hondas and the Ford Focus. Their quality tends to not be the best.
That said, I didn't read all 8 pages of this thread, and if you guys have good luck with 'em, then more power to ya! But if you are wondering why the OBX is less expensive than others, well, it's designed that way.
#253
Coming from the Honda world I hear you loud and clear Jared! After looking at the dyno for this header and then looking at the price (sub $200 shipped vs $600-800 + shipping) I couldnt find any reason to buy it. The welding looks well done, although I havent checked fitment yet. I think for the money its a very competitive product
#254
Same from the Mustang world
a) sold as a luxo-comact, and they expect us to be able to pay.
b) parts are from small companies, and they just don't make many.
c) larger companies just charge more because of the channel costs for a small volume product.
Probably a bit of all three, but when a header with cat can cost over $800, OBX baby!!!!
Matt
#256
#257
I think the weld is stainless - stainless
From the little I know about welding, welding stainless to mild steel isnt usually the easiest thing to do, and once done its pretty shady.
#258
Great stuff, nice pictures and write up.
Excellent, Glad to hear that!
Andy's comments earlier about VW's with CAT's that were to large. I think he was referring to them flowing to much with not enough differential between the two O2 sensors causing them to set codes. I built a system once for a 2 liter double over head cam running without a resonator, way to loud. I put a glass pack in to act as a resonator, it killed the high frequency and sounded nice after that. If doing it again I would buy SS Res.. I found these nice SS resonators and other exhaust parts here;
[size=2]http://stores.channeladvisor.com/vertexnow/Resonators/Vibrant/?sck=54376669[/size]
I'm going to use two of these size=2]http://stores.channeladvisor.com/vertexnow/Items/TAS-250?sck=54376669[/size][size=2] on the OBX provided socket and one on a made up coupler flange at the other end of CAT which attaches to my Magnaflow flange. This way if the CAT goes south I can easily replace the CAT.
[/size]
[/size]
Originally Posted by Dr Obnxs
But I'm still working on sound. Still too loud!
Matt
ps, I've been putting it through the paces, and I haven't seen any codes, even hammering the motor when cold....
Matt
#259
Originally Posted by inimmini
I find that on the stock header, the pipe leading to the cat is non-magnetic, as well as the flared ends of the cat. A magnet sticks to the cylindrical portion of the cat. So, I would guess that flared portion of the cat is stainless, which is where the the OBX will be welded.
I guess you have a point. for $200, if it ends up being a piece of crap, who cares? better than spending $700 and having THAT be a piece of crap
#260
I called JetHot and got a quote for $150 plus shipping. I had it done on a 428 CJ motor and no problems so far. I went with what worked before. I just need to figure out the cat part. If there is no benefit of changing over stock or marginal gain, I'll stick with that, but the stainless to mild steel issue is something that concerns me. I had a failure on a joint on another car, I'm sticking with all the same material somehow.
Keep the faith.
Keep the faith.
#261
#263
Keep the faith.
Keep the faith.
I think im going to do that myself....Good stuff. ....I know this prob has been debated b4 but, is there any difference with or without a cat?
#264
#265
Originally Posted by JPit
I installed the OBX header also and when I talked to a tech. at Magnaflow they did warn me about using a cat that was too big (flowed too much).
#266
It will effect start up emissions
Originally Posted by 1FSTMINI
I find that hard to believe.....the only purpose of it is for emissions and nothing else....putting a cat which is bigger than the oem size isnt gonna do a thing but prob give you a different exhaust tone and even clean your HC reading even more.
Matt
#267
Somewhere earlier in this post, two owners gave different model numbers of a Magnaflow cat they were going to use with the OBX. I called Magnaflow and talked with one of their technicians. He asked the size of the MINI engine and said that one of the cats should work fine but the other was much too big (too much flow) to work properly. I accepted this without asking him why.
#268
#270
Remember we have a blown motor....
Matt
#272
The Eaton web site says
Originally Posted by andy@ross-tech.com
Yep, and the supercharger eats some power too. Airflow for a normally modded ~200 bhp MCS (pulley, intake, exhaust) is roughly comparable to a 250 bhp n/a engine.
Matt
#273
#274
Andy, I was refering to this post.
norm03s,
I take it you haven't had any problems with P0420 Catalyst System Efficiency Below Threshold? This problem shows up a lot in the VW 1.8T and different cat companies have different success rates with it:
http://forums.vwvortex.com/zerothread?id=663057
#275
2007 Mini
Originally Posted by SRTech
I saw an electric water pump somewhere, but it was super expensive. Electric accessories still cause loss from the increased current draw from the alternator, but how much I don't know. You would probably have to increase the output of the alternator, also.
Steve
Steve
I've seen a kit that uses the 6 series electric pump for over a grand, but if it gets you 15-20 hp, better hp/$ than lots of stuff.
Matt
