Drivetrain OBX-Racing Header Dyno Results!
Old 10-20-2005 | 05:18 AM
skuzy's Avatar
skuzy
how much louder will the headers make the exhaust??
  #377
Old 10-20-2005 | 08:19 AM
J0kER's Avatar
J0kER
the exhaust is 2.5 but not all the way to the tail, its smaller into the canisters!!
Originally Posted by zrwon
OBX/Milltek would be the perfect set up since both are 2.5", someone had this done on an 05 Cabrio and posted yesterday, that might be what I'll do once I decide which header I'm using.
  #378
Old 10-20-2005 | 09:41 AM
Bahamabart's Avatar
Bahamabart
My experience not much but a bit deeper sounding.
  #379
Old 10-20-2005 | 09:38 PM
Dr Obnxs's Avatar
Dr Obnxs
If there are two....
then it's not that bad. Depends on the different radius of the tube.
And horrible piece of metal? For a~$600 difference in price, I'd put up with a stud or two....
Matt
  #380
Old 10-20-2005 | 09:46 PM
zrwon's Avatar
zrwon
Smaller? how much smaller and the canister are you talking about resonator or muffler?
  #381
Old 10-20-2005 | 09:50 PM
Dr Obnxs's Avatar
Dr Obnxs
A little math goes a long way...
for the exhaust that split into two pipes, the diameter must be at least 71% (or 1.77") to maintain cross sectional area. Because of boudary conditions, this should probably be bumped up to 1 7/8 or 2".
Matt
  #382
Old 10-20-2005 | 09:51 PM
J0kER's Avatar
J0kER
"two" what?
is the second sentence directed towards me?
Matt
  #383
Old 10-20-2005 | 10:00 PM
Dr Obnxs's Avatar
Dr Obnxs
Sorry, not enough info in the post.
"two" what?
Red Fury called the OBX a "horrible piece of metal". From price performance, I don't agree. I had one stud I had to use. I think someone else had to use two. Still, at less than a third of the price of most competitors, it's a value. But the Pilo Racing Header is close in price (now, wasn't available when the thread started), so the balence is changing.
The other reference was speakiing to "not being 2.5 inches all the way back". Here, when the pipes split into two, the cross sectional area of the two pipes has to be at least as much as the larger pipe.
Since I don't know you, I don't know if you're a Stud or not!
Matt
  #384
Old 10-20-2005 | 10:41 PM
skuzy's Avatar
skuzy
Old 10-20-2005 | 10:56 PM
zrwon's Avatar
zrwon
$230? I bought the OBX and am missing parts, then I bought the other one on ebay (I haven't got it yet) but now you show me this one and it looks so much better, now if I buy this one too, I'll have 3 to chose from but will have spent more than the Milltek after shipping on all 3, man sometimes I wish I would wait a little, at the time all I could find was $800 or the OBX at $175, so I bought the OBX and now there's all kind of others surfacing.
I will wait for the exhaust, otherwise I'll run into the same BS again.
Thanks for sharing though, now I wish I wouldn't have bought anything yet.
  #386
Old 10-20-2005 | 11:55 PM
skuzy's Avatar
skuzy
zwron i have the same feeling.
try selling some of your parts.?
btw see the other thread u posted on about exhausts (i may have made thigns worse with ur options )
  #387
Old 10-21-2005 | 02:10 AM
johnD's Avatar
johnD
Coordinator :: ClubMINI.ph
But the 2 headers aren't exactly the same, so there are other factors to consider other than the price and fitment issues. The OBX/Supersprint header is a 4-2-1 header, which means the gains are in the lower part powerband than with a 4-1. I think for the street the OBX/Supersprint would still be best, but for the track, maybe a 4-1 (Pilo, Milltek, etc.) is better. Just my two cents. :smile:
John
  #388
Old 10-21-2005 | 03:54 AM
Bahamabart's Avatar
Bahamabart
John
Its just a matter of what you are seeking to accomplish. AND isn't it nice to have choices for 200.00 I did the the OBX and am very pleased with the results.
  #389
Old 10-21-2005 | 04:47 AM
skuzy's Avatar
skuzy
iam seriously considering OBX header simply because of its low cost.. if i had money to blow it would be MTH header. but going ot cost me too much.
  #390
Old 10-21-2005 | 07:14 AM
J0kER's Avatar
J0kER
right~0n!
so ur sayin' that as long as the flange is as big as the pipes b4 the smaller pipin' begins then its all good?
Matt
  #391
Old 10-21-2005 | 07:58 AM
J0kER's Avatar
J0kER
im pretty sure its 2" it looks smaller but i doubt it.....
well its much smaller than the the rest of the pipin' (from cat to rear flange) It looks to be 2" after the rear flange it all goes down to the canisters & out in this smaller diameter.
i had the 'playmini/Scorpion' & it wuz BIG & i mean BIG the whole system wuz huge, the canisters and all ( no resonator) the pipe wuz 2.5" from tip to tail & the canisters were huge compared to the Milltek, but they hung low in the rear which for me wuz a major turn~off. //the playmini made up for the straight pipe by addin' bigger canisters.//
but that system (Playmini) is key if u want to stay w/a true 2.5" non resonated exhaust!!!! its a real NiCE piece if i had my choice in tips & canister size i would have run the playmini!! but oh well im on to my next big MOD (header) now so it will do.
BTW the tone of both these systems ROCK. & i've heard a slew of different exhaust's out there by far these are the best!!!
  #392
Old 10-21-2005 | 06:09 PM
inimmini's Avatar
inimmini
Originally Posted by RED FURY
THAT SOUNDS LIKE A HORRIBLE PIECE OF METAL ... POOR FIT
Well, the OBX does have some fitment issues, but horrible is a bit harsh. Apparently, my install was tougher than most, but the end result rocks. I don't know if a header tends to "break-in" like an exhaust, or if the ECU has learned better how to run the motor, but the resonance I mentioned earlier seems to be gone, and the pull at low rpms is just plain great!
It looks like the newest low cost header shown in post #358 would not have the same fitment problems as the OBX, since the pipes appear to join the cyl head flange at a 90 deg angle, whereas the OBX are more slanted. This slant causes the difficulty in bolting it up. However, if the 4-1 design does not bring the torque improvement of the OBX (Supersprint) 4-2-1, would still go with the OBX, in spite of the finicky install.
  #393
Old 10-21-2005 | 06:13 PM
J0kER's Avatar
J0kER
what were ur issues?
u mentioned 'difficult to bolt up' wuz this it? as far as "issues"
  #394
Old 10-21-2005 | 08:51 PM
inimmini's Avatar
inimmini
Read post #366
  #395
Old 10-21-2005 | 08:56 PM
J0kER's Avatar
J0kER
********** post 366 *********
i did read this b4 but totaly wuz lost for a minute...
....thx
Got the OBX header installed at Helix last week. I'm glad Eric charges a flat rate for this -- the job took ~ 6 hrs. Well, some of this time was waiting for the header to cool off after I arrived, and then Eric had to run out for SS welding wire. But I think the OBX header was on and off the car about 5 times getting it to fit. Two of the bolts had to be replaced with studs, and some of the bolt holes had to be opened up.
In spite of this, it is good improvement. The whole speed-torque curve seems to be shifted about 500rpm - in other words, it now pulls as well at ~2500rpm as it did at 3000. Really makes the car more fun to drive. Previously, when I launched without quite enough gas for the clutch release, the engine would bog for a second. No more. It just pulls through. Hills that used to require a down shift from 4th to 3rd don't anymore. This mod is similar to the pulley, makes you wonder why it wasn't like this from the factory.
The header does add a bit of noise at times, occaisonally a resonance in the cabin around 4000rpm. But mostly, the sound is just slightly different, a bit deeper and/or more raspy. Overall, I'm happy with the choice of changing the header rather than the more conventional route of a cat back.
  #396
Old 10-23-2005 | 08:25 PM
ripley's Avatar
ripley
OK, so I'm getting ready to make this mod but there seems to be some issues with the flange bolts. I assume it's because of the angle of the pipes. True? Just so I'm prepared, what size and length of studs are required?
thx, ripley.
  #397
Old 10-23-2005 | 08:49 PM
inimmini's Avatar
inimmini
Right, the way (some of the) pipes angle, you can't get the bolts started in the threads. The interference is greatest when the bolt is all the way out, i.e., if you could get it started, the clearance opens up as the bolt screws in. That is why a stud (meaning a threaded rod) works in this case, since you can first screw it into the cyl head, then put on the header, and add a nut to the short end on the stud poking thru the header flange. The short protrusion of the stud gives a bit more clearance for the nut.
I don't know the size Eric used, but obviously the threads & diameter are the same as the header bolts, and the length looked to be around 1".
  #398
Old 10-23-2005 | 09:16 PM
J0kER's Avatar
J0kER
i watched an install on this but w/a different header & they had a hard time w/this same issue (bolts) mayb its not the header but the angle...is all!
  #399
Old 10-24-2005 | 07:43 AM
ripley's Avatar
ripley
Has anyone installed one of the 4-1 units yet??
  #400
Old 10-25-2005 | 06:29 PM
skuzy's Avatar
skuzy
can u blokes with the obx/miltek combo pls post some CLIPS!!
cheers
Quick Reply: Drivetrain OBX-Racing Header Dyno Results!
