Drivetrain OBX-Racing Header Dyno Results!
#551
Does the Good Doctor care to take over?
Jim
#554
First, running without the cat will throw a code because of the second O2 sensor. The computer measures the difference between the two readings to adjust the A/F ratio of the engine to optimize performance. If you eliminate the cat the computer thinks the cat has gone bad.
The donut connection has the spring loaded bolts as part of the deal. These allow some movement to be absorbed at the joint. If you eliminate the donut by welding the exhaust system will find another place to fail. Before that happens you'll probably heave all kinds of noises from the exhaust pipes banging into the heat sheilding under the car. There's not a great deal of room.
#555
#556
Good luck
Alain
#558
#559
#561
OBX gasket replacement
Here is a replacement gasket that should work.
http://www.hotseatperformance.com/ps...2669&CATID=249
Posting this again so it doesn't get lost again.
#562
The picture of the Ebay ad I purchased from shows it with a flange attached..not just a coupler. I wonder if it is a newer style?
http://www.fuzionetics.com/ebay/new/H10350S_4.jpg
...and it better come to me as pictured!!! :P
#563
I don't think I have ever seen a pic of the OBX header that did not have that flange on it.....
#564
#565
It is suppose to come with it but if you bought it from the same guy as I got mine from, you will never get it, I've waited, emailed him and waited some more and he will never send it, I was missing the gasket and the flange with the bolts and springs, that was 2 years ago and my header is still in the box, so if you ever find one of these, let me know, I need one to.
Good luck
Alain
Good luck
Alain
#566
My take a few stops but someone will have it for you.
#567
#568
cut and weld cat
My obx arrives next week.I assume that the cut and weld part(cat) can be done on a table and then simply bolted back up to header and cat right?-or does welding have to take place under car?
-also:Is there any harm done by driving to a second destination(muffler shop) after header install?
I might be able to have a friend with TIG weld it.
Do the o2 sensors easily re attach?
thanks
thanks
#569
See post #62 in this thread for a photo of my OBX/stock cat setup.
https://www.northamericanmotoring.co...&highlight=obx
Jim
Jim
#570
A few things about an aftermarket cat flange to the cat back exhaust. The center-to-center on the OEM header’s cat flange bolt holes is narrower than the U.S. standard for two bolt flange spacing. A standard two hole flange can be adjusted with a rat-tail file or enlarged with a drill bit to fit; if it is stainless steel, the filing method is a lot of work. I’m sure “metric” flanges are available because all our aftermarket MINI cat backs are supplied with them, but I haven’t located a source. One option is a slotted flange that will accommodate any two bolt spacing and bolt diameter in the universe http://stores.channeladvisor.com/ver.../Items/vibef2b? .
Some fun facts about our OEM flanges, the cat back’s ID at the flange is less than two inches because of the weld bead and small diameter (2.1 inch OD) transition pipe. The cat’s exit ID is only slightly lager than 2 inches because of the weld bead. When using an aftermarket 2.25 ID flange on the cat and mated with an aftermarket cat-back, use an aftermarket gasket also because the OEM gasket has a smaller ID. If running a 2.5 inch cat-back, consider going 2.5 through the cat; the OEM cat can be modified with a larger exit pipe if you chose to keep it.
#571
thanks
thanks
2) The proper steps are -
install header, install exhaust and then measure the distance between the two this is what you want the cat with flange/connectors at each end to "fill".
TOO LONG and it will push your exhaust back - possibly forcing the tips to stick out more. TOO short and the inverse happens.
3) remember to double nut or cooper the header spring bolts
4) remember not to over tighten the spring bolts - should be about half way compressed springs.
5) many have done header and then finished the exhaust elsewhere, myself included. Its cool for about 3 minutes. People stare and cops pull you over .
6) sensors go right back in.
#572
1) you should do a Stainless steel weld.
P.s.Have you or anyone else actually talked to someone at sparktec?
I'd like my tracking info for my header.
thanks all
#573
Good luck!
Matt
#574
Awesome....I had a feeling that was the case. It's funny(not really)that on their website they say how important customer service is to them.They give you 3 ways to contact them(failing to list their phone #"you can reach us by phone at,"......nuthin.The entries on this thread show a dismal record of email response.I'm jonesin' for my new loud friend!!!Wheres my header!
#575
