Drivetrain More HP from improved grounding?
Yes, I'm skeptical, but I ran across this on another s/c forum, and apparently magazines such as Import Tuner have tested and verified the gains. I'm still skeptical, but hopefully those of you in the know can fill in the blanks. Here's the site for the manufacturer: http://www.speedoptions.com/eh/default.htm
total b.s. to scam the technically illiterate. may as well get a tornado gizmo while you're at it......
i suspect the testing of the "imrovements" is like that claimed from some spark plugs and from some ignition gizmos. if the components, especially spark plugs, are old (or here, you have a bad ground), you can show improvements by just replacing the old part with a new one of the identical part. so if you replace the old worn one with your gizmo and show improvement, well, then, yessiree, bob, we have the engine elixir right here......
I went digging to try to find the article in Import Tuner that was mentioned at the other forum. Couldn't find the article, but found several references to the product on other tests the magazine has performed. Ended up going to the website of the company, and here's what I found (with dynos): http://www.sunautomobile.com/
I'm STILL skeptical, but this tweaks my interest.
yea, back from the dead i know :D
I did end up making these kits after a friend talked about getting shocked all the time getting out of her car. With the kit, it seemed to diminish some. As for making the car faster, better, who knows. I do know that most people that have bought it, have liked it.
Shane
Shane
Originally Posted by 10851CS
A local person was selling this "system" of grounding with the idea it worked so he wanted a MINI to put it on to show. I went to his place, poped the bonnett and he looked and said he didn't see anywhere to ground it that wasn't already done. He decided not to make it for the MINI.
Earl
Earl
so when you ground the car you get improved the voltage power and that will help your improve your spark at high RPM... or "more HP"
now minis are well grounded from the factory... you can test it yourself, all you do is get a voltimeter and test different parts of the engine bay.
my advice... dont waste your time, unless after the testing you find that the areas you tested are not well grounded.
Carlos
These things are discussed fairly routinely on the VW/Audi 1.8T forums. Generally small skirmishes break out between the kool-aid drinkers and the nay-sayers with no proof of performance/lack of performance to be shown from either camp.
Stopping the shock from getting out of the car would be nice, though I only notice it in the cold months.
Agree with ScottinBend. This device would have no effect on static charges, the shock from which comes from a difference in potential between you and the car. Either you or the car acts as a capacitor holding the charge until enought voltage exists to jump the gap, measured in thousands of volts.
Only a poor connection between the car and battery would be helped by this device.
Originally Posted by ScottinBend
Getting shocked while getting out of the car comes from the clothes you are wearing. Has nothing to do with the cars grounding.
Have you ever noticed little antenna on the ground as you approach a toll booth? They are there so that you don't shock the attendant while handing them the toll. Same idea.
on
Emnotek
09-29-2015 07:37 AM
