Drivetrain How to Remove Injectors from Fuel Rail
Can someone give me directions on how to do this? I have removed the black steel lock holding the injectors and fuel rail together but still it won't come off. Are the injectors threaded into the fuel rail or do I just pull the injectors out? Do I need to depressurize the fuel rail to do this? Thanks!!
John
John
Just pull (with some force, but not much). They come outta there, I promise.
Be sure you disconnect the fuel rail from the fuel lines before doing so.
John
John
As long as the clips holding the injectors in the rail have been removed - they will pull out. It may require some force.
RedBaron,
Do you mean using as much force as when you pull the injectors and fuel rail out of the head? I already have the fuel rail off the car and in my lap, all lines are out. Thanks!
John
John
