Drivetrain Official ALTA Q&A thread!
Old 12-02-2005, 02:48 PM
ALTA2's Avatar
ALTA2
ALTA2 is offline
Manufacturer
Spiderx,
My bad, you said black intake, i am thinking black intake tube, not filter. No black filters yet. Actually the filters are made in the US. I will call you in a few!
  #402
Old 12-02-2005, 04:35 PM
Dr Obnxs's Avatar
Dr Obnxs
Dr Obnxs is offline
Now that you have a good rep,
Originally Posted by ALTA2
Thank you for the compliment! Being our first SEMA we tried very hard to make a good first impression. I am glad it worked!
you can become non responsive!
Matt
  #403
Old 12-07-2005, 11:00 AM
Kentiki's Avatar
Kentiki
Kentiki is offline
Sorry if this has been asked before, but is it possible to buy the Alta intake filter only?
Old 12-07-2005, 11:19 AM
mdsbrain's Avatar
mdsbrain
mdsbrain is offline
In case you want one to replace a dirty one these can be cleaned. But if its something else then more power to you
  #405
Old 12-07-2005, 11:36 AM
ALTA2's Avatar
ALTA2
ALTA2 is offline
Manufacturer
We do sell them separtely! But we also have the cleaning kits which can revive a drity very easly.
  #406
Old 12-07-2005, 12:21 PM
Kentiki's Avatar
Kentiki
Kentiki is offline
Great thanks to both responses. I looked on the Alta website, but didn't see the filters offered. How much is one?
Ken
  #407
Old 12-08-2005, 12:20 PM
ALTA2's Avatar
ALTA2
ALTA2 is offline
Manufacturer
They are $60, and instock.
  #408
Old 12-12-2005, 09:01 AM
protoculture's Avatar
protoculture
protoculture is offline
Dumbest Alta Question Ever Award? I'm seeking the nomination...
Alright, I've got my catch-can installed (at the frame location, adjacent to the i/c). My question is: How do you drain the can? The bottom piece is mounted to the frame bolt, so the whole thing can can't come out--asuming I'd even stick a socket into that oil/water muck.
Do you just undo the top connection of the clear sight-gauge line and drain it from the bottom, or... ? Apologies if this has been answered before, I searched the forums and couldn't find the answer.
Many thanks.
  #409
Old 12-12-2005, 09:06 AM
dominicminicoopers's Avatar
dominicminicoopers
dominicminicoopers is offline
Originally Posted by protoculture
Do you just undo the top connection of the clear sight-gauge line and drain it from the bottom ?
Yes, this would be the preferred method for that mounting location. :-)
  #410
Old 12-12-2005, 11:22 AM
ALTA2's Avatar
ALTA2
ALTA2 is offline
Manufacturer
You got it! Remove clear tube from top and dump! Or some people have used basters!
  #411
Old 12-12-2005, 05:46 PM
protoculture
Thanks much, folks! No small irony that I had nary a problem installing it, and then this 'simple' thing stumps me.
  #412
Old 01-24-2006, 12:50 AM
Strom's Avatar
Strom
Strom is offline
ALTA,
Any word on CARB certification for the intake?
Thanks!
  #413
Old 01-24-2006, 12:58 AM
MSFIT's Avatar
MSFIT
MSFIT is offline
Originally Posted by Strom
ALTA,
Thanks!
just hittin up all the forums tonight huh
  #414
Old 01-24-2006, 09:01 AM
ALTA2's Avatar
ALTA2
ALTA2 is offline
Manufacturer
Strom,
Around Summer time you will start to see some info. As we get closer to summer we will keep everyone posted on the progress.
  #415
Old 01-24-2006, 09:18 AM
Strom's Avatar
Strom
Strom is offline
Just tryin' to help you out, man.
  #416
Old 01-24-2006, 09:19 AM
Strom's Avatar
Strom
Strom is offline
Strom,
Thanks!
  #417
Old 01-24-2006, 03:33 PM
dairyboy's Avatar
dairyboy
dairyboy is offline
With respect to the turbo kit, why isn't there a blow off valve?
  #418
Old 01-24-2006, 04:28 PM
obehave's Avatar
obehave
obehave is offline
Designed properly, it might not need one.
  #419
tools's Avatar
tools
tools is offline
The only problem that I have had with your products have been the rear end links. The first set had hymejoint problems and your company replaced the joints. It has been 4 months and they are going bad again. So I gave up and put the factory ones back on.
Little disappointed especially based on the price that I paid for them.
  #420
Old 01-24-2006, 05:07 PM
ALTA2's Avatar
ALTA2
ALTA2 is offline
Manufacturer
dariyboy,
There is BOV included, sorry if we missed it in the pictures, but it should be there. The kit does need a BOV, due to the higher boost we are running. Some cars that have Turbo kits for NA cars, don't use them because of the low boost. But it surely needs one on this application.
tools,
CAn you describe your problem? We have had very good, trouble free performance from the rear endlinks. There must be something going on with yours if this is the second time. Lets figure that out!
  #421
Old 01-24-2006, 05:36 PM
dairyboy's Avatar
dairyboy
dairyboy is offline
Thanks for that, I've also sent an e-mail to Adam 2 days ago re dealer application but haven't heard anything yet.
  #422
Old 01-25-2006, 01:09 PM
ALTA2's Avatar
ALTA2
ALTA2 is offline
Manufacturer
Whats the name of the company? Adam will get back to ASAP.
  #423
Old 01-26-2006, 05:51 PM
dairyboy's Avatar
dairyboy
dairyboy is offline
See PM.
  #424
Old 02-13-2006, 05:28 AM
wohi's Avatar
wohi
wohi is offline
Question to mounting of the LW Crank Pulley
Hi !
I've heard about cases of loosening lightened crank pulleys..
Any cases / reasons known here ?
Maybe caused by different termal expansion of steel and alu - what do you think about this risk ?
Couldn't find any detailled "how to mount" instructions in the net..
Thx and Regards,
Wolfgang
  #425
Old 02-13-2006, 08:33 AM
ALTA2's Avatar
ALTA2
ALTA2 is offline
Manufacturer
wohi,
We have never heard of this! The crank pulley is a press fit on to the nose of the crank, and as a secondary "holder" there is a large bolt to hold it on. So beside the press fit the bolt should hold it on as long as it is tight!
There used to be a how-to from Webb??
Quick Reply: Drivetrain Official ALTA Q&A thread!
