Drivetrain Official ALTA Q&A thread!
Old 01-31-2009, 01:11 PM
BlackSapphire's Avatar
BlackSapphire
BlackSapphire is offline
What is the filtering performance like on the foam Alta CAI? I've heard that they flow more air but also let larger particles through. Has this been a concern?
P.S. I just placed a large order with Alta today! Yea for me!
  #1477
Old 01-31-2009, 01:28 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
ADAMSALTAMINI is offline
FIRST: Thank you for the order!
SECOND: Totally backwards! The ALTA Foam Filters trap smaller particles, vs. the K&N style filters. So better filtration, better protection of your engine, supercharger and power gains! Cleaning is easy, and doesn't require lengthy drying time like K&N style. You will be VERY pleased with your choice!
THIRD: Please let me know if I can help with this or any other concerns. Thanks again!
  #1478
Old 01-31-2009, 01:38 PM
BlackSapphire
Awesome Adam. Thanks for the info. My car has 150 miles on it - just making sure.
Also ordered the lower control arms, sway bar, stubby antenna, filter cleaning kit, etc.... that 10% off had me clicking and clicking.
Next up are Alta sway bar endlinks (front and rear), M7 strut tower brace, Alta rear brace, and probably some turbo tube stuff. Keep up the good work!
  #1479
Old 01-31-2009, 03:43 PM
ADAMSALTAMINI
NICE! My kind of MINI guy! Chat soon!
  #1480
Old 02-09-2009, 03:59 PM
MUShadd's Avatar
MUShadd
MUShadd is offline
I just installed my prosport boost gauge last week, its driving me nuts. It will not stop rattling. I finally figured out what exactly was causing the noise. the silver push button for the peak is hitting off the lens. it has just enough movement to contact the edges of the hole in the lens that it passes through. Is this a common issue? also, one of the plugs in the back either has a short, or simply not making good contact with plug-in on the gauge. The slightest movement sets if off and the needle blasts to the peak and alarms because it senses its not connected. i jiggle the plug and it'll eventually return to normal. Do i have a bad gauge?
  #1481
Old 02-09-2009, 05:21 PM
BlackSapphire
Jeez... It sure sounds defective. :(
  #1482
Old 02-09-2009, 07:15 PM
ADAMSALTAMINI
Hi Mushadd,
Sorry you are having issues. On the silver button, there are some remedies for that, but if the connections are having an issue the solution to the first is mute.
NOT a common problem. While I appreciate the post here, a quick call or e-mail to us and we would have had this solved! PLEASE PM me your contact information, inv# etc. so we can get the ball rolling on a solution tomorrow.
Thanks again for choosing ALTA!
  #1483
Old 02-10-2009, 05:06 AM
MUShadd's Avatar
MUShadd
MUShadd is offline
Guess I have too much free time during class, sorry PM sent!
  #1484
Old 02-10-2009, 09:08 AM
ADAMSALTAMINI
Hey I didn't get the PM. Where did you send it? Let me know! Thank you!
NEVERMIND! Found it!
  #1485
Old 02-10-2009, 09:19 AM
MUShadd's Avatar
MUShadd
MUShadd is offline
Got a call from Chris, connection issue solved. will work on the suggestion for the rattle as soon as i get some extra time. Thanks for your help guys
  #1486
Old 02-12-2009, 10:58 AM
BigHarv's Avatar
BigHarv
BigHarv is offline
Greetings.
I just ordered a set of Kong Feather 17"s from you folks for my 2009 MCS. I really hate the runflats that the car came with so I'm replacing wheels and tires. What tires do you recommend for a quiet ride that will still stick to the road like glue? If they have anything you would recommend, I'd really like to stay with Les Schwab for their excellent service.
Harv
  #1487
Old 02-12-2009, 11:33 AM
ADAMSALTAMINI
Originally Posted by BigHarv
Greetings.
Harv
Thanks for the order Harv! I use a Falken 235/40/17 Azennis on my car and I have been very happy with them. Very quiet, reasonable price etc. You can get them in other sizes as well. I think they carry these at Les Schwabs as well.
  #1488
Old 02-12-2009, 11:58 AM
BigHarv's Avatar
BigHarv
BigHarv is offline
Adam,
Thanks for the quick response. Your website recommends 215/45/17 tires with the Feathers. But 235/40/17 will fit too? Any advantage to one size over the other? Any other sizes that will fit on a late model MCS (R56)?
  #1489
Old 02-12-2009, 05:33 PM
BlackSapphire
Outstanding! Any more pics of this setup Adam? This is the first I've seen of 235/40s... The size is very similar in overall outside diameter but with some extra width. Any rubbing? What springs are you running?
Your fellow Konig Feather owners want to know!
  #1490
Old 02-12-2009, 07:50 PM
ADAMSALTAMINI
I have the car lowered on the H&R Coilovers. I trimmed a few mm of a small area in the front lips. But no other changes needed to make em fit. I also have 5mm H&R Spacers on the car too.
More Pics CLICK HERE
PLEASE let me know how I can help in anyway further!
  #1491
Old 02-12-2009, 08:57 PM
BlackSapphire
Very nicely done. You nailed the stance Adam.
Thanks!
  #1492
Old 02-19-2009, 10:42 AM
BlackSapphire
Jeff, it would be greatly appreciated if you would answer my PM from yesterday.
  #1493
Old 02-19-2009, 11:11 AM
ADAMSALTAMINI
Jeff has been working on some special projects away from his desk. Either PM me, or PM ALTA_Chris either of us can address concerns faster than Jeff for the next few days.
Thanks again!
  #1494
Old 02-19-2009, 11:13 AM
BlackSapphire
Thanks again!
Will do - appreciate the quick response Adam.
  #1495
Old 02-24-2009, 10:10 AM
sonichris's Avatar
sonichris
sonichris is offline
PSRS question
i'm about to install these. my question is about alignment of the bushings in the 45deg position. opt2 recommends lowering the rear of the control arm for anti-lift. what if i raised the rear? this would (since my car is lowered) bring the control arms closer to level when looking from the front of the car, which would help roll angle in turns. my car is very stiff already and i don't think i need anti-lift anyway.
thoughts?
  #1496
Old 02-24-2009, 03:58 PM
not-so-rednwhitecooper
not-so-rednwhitecooper is offline
http://altaperformance.com/products/...-Pod-no-gauge-
Does the gauge pod come with just one pod, or two?
It says at the top dual 52-60mm, but in the included items it says "gauge pod" (singular)
Thanks!
  #1497
Old 02-24-2009, 04:17 PM
ADAMSALTAMINI
Thanks!
Sorry for the confusion. They are single pods, up to two can be purchased (I have mounted as many as three) to then mount one on either side. The pods come with adapter rings to allow either 52mm or 60mm gauges to be mounted.
Hope that helps. If not PLEASE let me know!
Thanks in advance for choosing ALTA Performance!
  #1498
ADAMSALTAMINI
thoughts?
Please call our offices and speak to either Chris or Jeff in tech to be 100% sure! Thank you!
  #1499
Old 02-25-2009, 10:31 PM
MUShadd's Avatar
MUShadd
MUShadd is offline
do you guys have sponsorship opportunities?
  #1500
Old 02-26-2009, 09:39 AM
ADAMSALTAMINI
Thank you for asking. At this time we are not accepting sponsorship applications other than those cars to be featured in magazines or the SEMA show.
Thank you again!
Quick Reply: Drivetrain Official ALTA Q&A thread!
