Drivetrain oil parts
i still have to make a blank-off plate to replace the existing oil filter housing, suitably tapped for the oil lines and temp/pressure senders. for the technical tyros: the filter is Canton/Mecca, the lines, cooler and fittings are -10AN, and the thermostat (and most of the components) are from Pegasus. Several sizes of cooler are available; I chose a smaller one with AN fittings/
JLM that is a very interesting project but I have a few questions.
1/ What was the reason you decided that the mini needed assistance in this area?
2/ What are the before and after deltas preferably at each 10 mph increment within oh lets say 5 different ambient ranges?
3/ What were the before and after DYNO numbers , SAE of course?
4/ what is the altitude of the dyno shop
5/ Could you provide the names and addresses of 5 witnesses unknown to you before the test?
6/ How will this affect my warranty?
7/ What long term testing have you done and how will this shorten or lengthen the life of my car?
8/ How much is your markup and what will you do with the profits?
9/ Could you please post your resume so we can be sure you know what you are doing?
10/ How will the added weight to the car affect the handling characteristics of the car?
11/ Will there be any additional brake wear do to the added weight? If so how much?
12/ How will the added performance off set the added weight in my 1/4 mile times?
13/ Can I get the hoses in green ? If not why not?
14/ What is your warranty and return policy ?
15/ When will you be shipping these ? Why is it taking so long ??
That should do it for now , if you can answer these to my satisfaction I may consider buying it . Welcome to the new NAM
actually, it is all store bought stuff; I ain't no retailer.
go to
www.pegasusautoracing.com
and go wild.
go to
and go wild.
go to
and go wild.
go to
and go wild.
I'm disappointed that conehead felt the need to bring the drama into an otherwise good thread.
Might want to check these guys out too;http://www.thinkauto.com/The site is lame but they have a lot of oil related components, flanges, etc.. :smile:
Ok,Ok I suck
Didn't mean to offend you... I don't know how or in what way
enough bs.. It would help us lazy folks if you could point out the parts or part no's
go to
and go wild.
go to
and go wild.
If MINI had used a standard spin-on filter like everyone else on the planet you could just get an off-the-shelf adapter plate to get your feeds. As it is, you're looking at something entirely custom, like JLM's proposing, or using something like the madness adapter (which doesn't allow for a remote filter, and is priced about 2-3 times what it's worth IMO).
The part numbers of all the fittings and hose will change depening on what size line you decide to run. Everyone has a different opionion, ranging from -8 to -12.
Kimolaoha
07-05-2023 01:04 PM
07-16-2020 12:54 PM
