Drivetrain Laminova core intercooler
The big cnc rectangle houses two finned (radiator looking) tubes, known as the laminova core (from opcon, the same company that makes the autrotor supercharger), water(or coolant) flows through this assembly then to a resovoir, then through the inline pump to the condenser (which happens to be a stock mini cooper s intercooler) then through the intercooler assembly.
As the water/coolant flows through the cores, air coming from the supercharger is flowing cross ways over the cores (all of this happening inside of the rectangle) which in turn cools the air and then continues on to the intake manifold.
The price is 2300. For everything. The temperature drops are anywhere from 280+ degrees before the intercooler and below 110 after the intercooler.
Oh and by the way MEB, Anthony is a very good friend of mine and he prepares my race car as well as advises me at races.
Thanks for the interest.
Christian
Christian
Interesting setup. Whats going on in the aluminum box upstream of your intercooler?
I like the laminova cores because the present interested packaging opportunities. Imagine two cores mounted in the intake manifold's plenum and the inlet location moved to directly above the supercharger's outlet. You'd have a straight shot into the intake manifold and would effectively eliminate all those funky turns in the intake path.
JLM, are you listening?
Cheese
Cheese
Clevy, I understood he was a friend and that he helped out. I just found it interesting that the shop looks familiar, and, that I have a friend named Anthony who also races, advises about racing and is an instructor...do you live near Salem, New York??? Meccanic's Shop North by chance???
Michael
Michael
Christian
Christian
gar56
11-15-2016 06:41 AM
