Drivetrain Bosch Injectors
Originally Posted by andy@ross-tech.com
I think he means injectors for a 225 hp Audi TT. They are 380cc as well and are used in some 1.8T turbo kits.
FWIW, I do not believe that the TT225 injectors are a direct fit.
If these are the injectors that you are talking about, then I can get the part number easily enough. Don't know what sort of 'machining' they require for the MCS (The majority of the body being plastic, with only the tip being a thin medal body) But unless you have machining capabilites, then i'm not sure what good it's going to do you. :smile:
dutchhome
09-30-2015 07:17 AM
