Drivetrain Pulley came apart
Pulley came apart
Well today I was driving behind my friend following him to his house and i lost all power, revs dropped, engine light on. Pulled over right away. Only mod on the car is a 17% three-piece pulley, it seems that the four screw that are supposed to hold the pulley together all stripped out, I thought they just fell out at first until I actually found one screw on the ground. I will add pics when I get some taken. The pulley fell apart somewhat but stayed on, the outer ring is eaten up by one of the inner rings. I haven't heard of this happening on anyone else car. I got in touch with some people in phoenix, gonna see what they can do about this issue, I don't want to have to pay for another pulley but I think i might have to. This really bites I have no pulley removal tool, I have no stock pulley, so there is no way that I can even get it running right now.
rant over....
rant over....
Bummer
I'm no expert, but I'd also tend to believe there was an issue with the install. Unless the pulley is: a) pre-owned, b) of questionable quality, or c) stripped out at installation... So how long ago was it installed? Where was it purchased? What brand is it?
The good news is it probably didn't hurt anything else, so you're just a new pulley away from being back on the road. And, you shouldn't have to pay full ticket to get it replaced.
I recall a posting on here someplace that some alta pullies had an incorrect torque spec. It listed the force in ft/lb's NOT in/lb's this is a big diffrence and is why some have been stripped. Alta has beed stepping up to the plate on this andmaking right from what i understand.
good luck
good luck
https://www.northamericanmotoring.co...ht=alta+torque
see post #15 for alta's response. They should be willing to get you fixed up right away.
Cheers!
Originally Posted by binkysmini
Whoa there. The problem there was NOT that Alta supplied the wrong specs. The problem there was that they were read wrong. The specs were correctly printed in in-lbs. But because in-lbs is such a rarely seen spec, it was overlooked, and tightened waayy too much. Alta has agreed to change it's instructions to make this more clear.
Cheers!
Cheers!
There are a couple of other brands out thre, and from the AZ reference, I can guess which on it is. We'll let him try to resolve it directly first. We really should have all the info before making any assumptions about the product.
One of the issues with using aluminum is stripping at a much lower spec, so this may be the case with this issue if the unit was overtorqued.
Randy
Randy
Originally Posted by Ryephile
--->misfit03: 1st, contact the manufacturer of the pulley. 2nd, contact your installer. I'm sure they'll prefer to work something out rather than get bad press, at least hopefully.
on
sharing info
The questions asked - make, installer, miles on the car,...) are reasonable questions and when a member feels he cannot share this info - then something is wrong.
A single experience is just that and it is important to capture these single experiences to see if a trend develops but if the board enviroment discourages communications then everyone loses even the manufacturers/vendors.
We all like to think we purchased the best part and are often defensive when someone disagrees. We all have our favorite vendors after all. The facts are there are many quality products on the market and some not so. Same applies to vendors/manufacturers.
I'd like to think that one experince be it negative or positive would not drive the buying processing for any NAM member.
I encourage you to
1) simply post "the facts" as well as post the end results - such as what did the vendor do? or the installer? And I encourage the board to take it as a "shared NAM member experience" and not a product condemnation post.
2) post it in product review. I don't think we post enough in the area.
BahamaBart
I encourage you to
BahamaBart
I had 2000 miles on the pulley (no real hard driving either), it was simple mistake of either over/forgeting to tighten down the bolts. I will let the manufacturer come out and say it was thier pulley if they want because I know that this pulley has been used on many cars with 60-70k miles. I contacted them and they are sending me a new pulley, they even offered to come to where I live to install it to make sure it is put in correctly.
Only reason I don't reveal who it is will be because I have respect for the people these people, and posting that up here might change other peoples veiws on the purchasing from them. I do not want to be the reason they lose business. So like I said, if they want to come forward they are more than welcome to but I leave it up to them.
If the above were true, this thread wouldn't exist.
So the purpose of this thread was to?
Warn us about your experience with the pulley? Doesn't do us any good if we don't know who's pulley it is...
Warn us about your experience with the installer? Still doesn't do us any good if we don't know who the installer is...
Provide us with a lesson learned about your experience? Don't know what we can learn without any real details...
So if anything this was a valueless rant....
Anyway, I think it has been well established that this was an installation issue, And any manufacturer/vendor that has gone to this length to get you back on the road should be praised and comended! If I ever buy a pulley I would go to this company....(me thinks it is ALTA, but that is my quess)
