Drivetrain Another oil catch can
I thought I would share my version of an oil catch can. It is made up primarily of two - 2" PVC endcaps glued together. The total cost was about 10.00.
The biggest concern I had with this design was heat so I installed a dummy and put a couple 100 miles on it. There were no signs of "melting" so I made one up and have 200 miles on it so far.
I'm not sure if that white PVC can handle the chemical components in motor oil. I was trying to find a definitive answer online...I did find this guide, which is actually pretty useful for plastics in general:
http://www.pep-plastic.com/manufacturers/nibco/m.pdf#search='pvc%20chemical%20resistance'
Notice that PVC is rated only for motor oil up to 140F. That is pretty low considering the catch can has engine fumes blowing by. Notice that CPVC is actually rated a bit higher.
Not sure if this is a risk or not, but I would be concerned that over time the PVC might begin to break down and then the broken down residue could enter the engine.
Originally Posted by Dr Obnxs
and has a Home Depot catch can!
Matt
Matt
Bahamabart, Great idea. A long while ago I shared another one.
I like the idea of using the Mopar breather cap because it has the oil condensing mesh already in it.
http://www.allpar.com/fix/pcv-breather.html
There I fixed it, just playing. It is really easy to be mistaken on intent.
Bahamabart, I appreciate your work
Last edited by norm03s; 10-16-2005 at 02:39 PM. Reason: Correct and add text so there aren't any misunderstandings
Just teasing....
Originally Posted by norm03s
He thinks he's inventive, why wouldn't he wear a Rolex?
Matt
You guys are a hoot! .
Rolex wrist installation guide.
1) order two Submariner 50th aniversery edition from an authorized Rolex dealer. Some dealers make you pay in full upon ordering, others will take a deposit.
2) Rolex sets dealer prices.
3) Sell one on Ebay - they are comanding about TWICE the price.
4) Place second one on wrist for FREE or sell both and all your MODS are free.
I ordered mine and waited almost 1 year to get them.
Originally Posted by fishbulb
can you explain what parts you used for your sight gauge?
thanks!
-jac
thanks!
-jac
6" piece of what the guy called "refrigarator" tubing.
I found the tubing first and then went to see what brass fitting worked. I believe the tubing is 1/8 inch.
I put off doing a catch can based on how many people installed one and said they say no oil. I installed this can about a month ago and was really surprised to see that it has collected about two table spoons already.
Maybe its my car in particular or perhaps the way I built it (i.e. I added an extension tube on the IN pipe, inside the can that runs 3/4 of the way down on the inside and then stuffed the can with copper stuffing top to bottom).
What ever the case may be this sucker is working
After having the Can on now for weeks, I wanted to update everyone that the PVC can has begun to change shape because of the heat. While its not "melting" it has changed shape due to the clamp I am using. On a long term basis, I don't think it will hold up and will eventually fail.
What did I learn -
1) PVC is not the way to go.
2) STUFFING the OCC with copper/brass "brillo like pads" noticably helps "catch" the oil.
3) Now that I have seen results on my car, I will be looking for a metal can solution.
All in all - it was a fun project.
What did I learn -
He thinks and he's inventive, why wouldn't he wear a Rolex?
Yup nice idea bec. the cap can help you fix it. ive done this before and bought a new cap then the spill stopped.
molala
10-02-2015 01:53 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
09-10-2015 12:34 PM
09-03-2015 03:01 PM
09-02-2015 09:05 AM
