Drivetrain Oil filter saga part II
Last time I checked in I complained about the oil filter housing leaking after every oil change - the O-ring breaks upon installation. Mind you, I've driven nearly 1.9 million miles so far in this life time, changed every filter myself with zero trouble.
Yesterday I performed another oil change. The filter was on correctly, and, the O-ring installed in its proper place. I replaced the old filter, but retained the old O-ring based upon a suggestion a month ago. I reinstalled the housing - this time I had no problem getting the housing to catch the threads. I tightened the housing down by hand and then gave a light snug with a 36mm socket - very light snug. Turned the engine on and it leaked like a mother. I took the housing off and the O-ring and filter looked fine. I installed a new O-ring and attempted to get the housing back on...it took 15 minutes of swearing before it caught the threads. Once the threads were engaged, I needed the socket to spin the housing on. Once tight the engine started with no leaks.
Every other time I replaced the O-ring, the filter leaked. Every oil change has consumed two O-rings; the first one breaks and the second one works.
I cannot figure this out. I change the oil every month based on my mileage. This is an absolute pain in the @#$^#^!!!!SS!!!!
Kimolaoha
07-05-2023 01:04 PM
Lex2008
08-16-2015 08:33 PM
