Drivetrain Greedy Emanage Ultimate
This is a question for the tuners on the board. I am installing a Emanage ultimate on my cooper s. I am trying to figure out what I should do for the ignition coil wires. There are three wires that go to the coil pack. One is power, one controls the coil for cyl one and two, and the other controls three and four. Will the emanage be able to understand these signals? And if so how should I wire it to the ultimate.
Originally Posted by Minirowski
People tried but nobody succeed. I haven't seen a working one in a MINI. Good luck! Sorry no help from here.
if you are looking for a clean RPM tach signal the coil pack is not the place for it without an Autometer tach converter.
the signal is not a clean square wave,
which I am guessing is what you are looking for,
I know this because I have a shiftlight and had to install the converter to get an accurate reading.
have you got a wiring diagram?
I installed a stewart warner shift light without a signal converter. I am not using it for a pulse signal. The Emanage can adjust the ignition advance. Look up the wirring diagram for the Emanage. It is a nice setup. Doesn't do anything to the map sensor. It actually adjusts the signals that the DME sends to the injectors and coil pack.
i have been in touch with greddy about the ultimate since it has come out... they are of absolutly no HELP! They are the friggin worse! If they haven't done it... they will just tell you not to buy their product... real confidence inspiring...
I would love for this to be a solution! Hopefully it works out... maybe... maybe... maybe... try finding out if a BMW harness is the same and then call greddy and reference them on the bmw... also... hit the bimmer boards... bimmerforums.com... and see if anyone is running it on their m3 or something like that... who knows... you may just find an answer... or you wont... and you will have to install a blast sheild and wear a flak jacket...
there's been two shops in japan where they seem to have installed the emanage with some of the features working.
http://www.real-direction.co.jp/frametop.htm
maybe pfunk who sells those JDM Mini parts can get some info from japan....
=topgearnut=
=topgearnut=
Originally Posted by kenchan
i think you're better off using a Apexi SAFC... PiloRacing, i think, was able to wire up successfully.
We have been running the afc on cars for awhile and while they have worked great I would love to have ignition timing! tHis car will make alot more power when we get the timing adjusted properly.
Originally Posted by isellem
no way! actually read about what an emanage does! It controlls ignition timing (assuming that you can hook it up)
That being said the MINI isn't some kind of magical car with a DME that can't be piggy backed. I believed that there were several nay sayers about the AFC a while back. We shall see whenever UPS decides it is time to show up with my package.
on
Originally Posted by not-so-rednwhitecooper
hey spillman, you got a wiring diagram for wiring up oen of those SW shift lights?
Dang... beat me to the punch! Never mind...
Originally Posted by spillman
Very true indeed. It is going to be difficult however playing around with the timming. The computer seems to keep advancing the timing until the knock sensor screams.
The coil actually fires 1,4 and 2,3 simutaneously.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
PelicanParts.com
05-21-2023 04:51 AM
PelicanParts.com
Accessory Products
10-01-2015 01:23 PM
