Drivetrain Power gains with a 17% pulley?
Originally Posted by omascow
I just got my 17% installed the other day with a gatorback belt and man does it scream like a banshee. I LIKE IT! But any way, from what I hear the power is in the low end torque. I tried looking for real dyno numbers comparing the two, but I never came up with anything.
Cool, thanks alot guys. Sounds like this thing is going to be a blast. I've also heard about some over-heating issues.....anyone know about that?
No overheating here and that's even taking Icarus on the Dragon. Well, maybe the brakes where a little warm. That extra power in a run like that takes a little more stopping power. I'm upgrading to braided brake lines, higher performance brake fluid and green stuff pads. Since I'm not autocrossing I probably don't need more than that.
I'm planning to go with a 2% oversized crank pulley together with my 15% SC pulley I already had installed.
I appears none of you went to larger injectors? Are any of you considering it? Also, did any of you who have an ECU tune (GIAC or MTH) notice a significant difference when you did THAT? Thanks.
I was one of the first (if not the first) to run a 17% on these boards and i luved it. I did not have any issues, was running stock software and injectors and there was not a day that i did not bring the car to redline in the first 3 gears.
http://a6.cpimg.com/image/E4/C5/2706...-01920200-.jpg
Man I miss my Mini.
Man I miss my Mini.
[QUOTE=vdubdoug]I was one of the first (if not the first) to run a 17% on these boards and i luved it. I did not have any issues, was running stock software and injectors and there was not a day that i did not bring the car to redline in the first 3 gears.
QUOTE]
Good to see you post again!
I have had the same experience, no problems
QUOTE]
I'm considering injectors but not yet. I would consider a throttle body upgrade first. I have yet to get AFR measurements done. Those will give MTH more info on fine tuning things both before a TB or injector upgrades. The measurements after that file would guide me in the correct direction as to which one to get first. At this time I'm thoroughly enjoying what I have. It's a blast and not one lick of trouble!
Some people throw everything on at once. I have a hard time not knowing what each mod is doing along the way without measuring each step (see MTH thread). If I threw everything on at once and didn't get the performance I thought I should then I could have a difficult time knowing which mod to focus on. The install costs are a little higher doing it one at a time but that's ok with me. I would rather be slow and steady so my car can be fast and steady.
tr3y003
33
06-05-2020 05:00 AM
JPMontes3
08-23-2015 01:26 AM
08-21-2015 11:25 AM
