Drivetrain Bypass Valve Adjustment Experiences...
#26
Originally Posted by Dr Obnxs
First time was a pain for me, now it's no big deal.
Matt
Matt
I think of it as one of those things you develop a technique for, like fitting the intake Snorkel on and off.
(sound effects were for humor I don't reccomend pyrothecnics while doing auto repair)
#27
VGS Happier
I just did mine, pretty easy, took about an hour just because I was taking my time.
Wow it really fixed my initial throttle take up, and just feels smoother through acceleration. Also my subttle yo-yo is better (originally really bad, but much better after v38.xxx).
This might be one of the best mods I have done. My spark plug wire upgrade made a huge difference on my car also.
Thanks to everyone and anyone on this mod!
15%, Alta CAI, ecu remap, kingsborn plug wires, colder plugs, tow hook.
#29
Matt...would you be able to verify something I've experienced?
When I had the VGS hooked up, cruising at a steady 75mph 6th gear showed an unGodly 250+ F preintercooler temp After reverting back to standard plumbing, the temp dropped to 150F area. I vaguely remember someone in the past mentioning this phenomena...what's going on?
Sid
Sid
#30
Originally Posted by gandini
You are joking, aren't you? Coz spark plug wires can't possibly make a difference, and this is from someone with $170 spark plug wires and $70 MSD coil...
cheers,
cheers,
My car was night and day different. I think my OEM plug wires are possibly faulty. How/why, I dunno, I am not super smart about engines and cars like many people on this site (which is why I read this site).
I am very conservative about what I do on my car with a limited mod budget. Read all the snake oil comments and threads I could find about plug wires, then found some Kingsborn really cheap, and thought...'worst case they will look cool under the hood'. Why looking cool under the hood means anything...I dunno again...
Disclaimer: actual performance may vary from one persons experience to another, and the butt dyno is not a scientific method nor reason for qualifications about product or results that may vary from said variable.
#31
Also, the VGS sees full SC boost, so make sure that the fittings are tight enough to not come off. I was paranoid and wiretied them after I did the mod.
Matt
Matt
#33
Sid
Sid
#34
#35
Since I'm the only other person that posted data it's me against Sid Grrrr! Arrgh!
Seriously though I ran and tested it on some 108º heat index days.
I had to pound it hard to even get to 200º. Temps returned to normal quite nicely. Normal being 130ish on a flat cruise.
So until other people get off their collective duffs and test this we have a standoff.
I trust Sid and I trust me so it must be his car that's F'd up
#37
I was the first one that put both the VGS and Ryphyx#2 (now called DT BPV). Looks like a few more are been added to the list from this thread. I have been running with the conbination for about 15k miles now. My Mini S 03 only has 25K, so most of its life. I have never had VGS only. I had DT BPV only and as Andy pointed out in the VGS thread, DT BPV does some funny things. The conbination smooth everything and is the best of both worlds, in my opinion.
Bomboasy
Bomboasy
#39
#40
#41
Ok, took a 10 mile drive...
From a dead stop, first gear is useless if you go anymore than 1/4 throttle.
Part throttle or stabbing it a low RPMs is where you feel the boost come on. With the mods I have, the car is a monster down low. Dont really notice anything above 4500.
I do notice if you life off in 1st-3rd and you are still going slow, you do feel the car buck since it still is getting air forced in but no fuel.
Overall I think its a nice change, and I can really see its benefits on the track!
#43
#45
Maybe you can put the DT BPV by itself and then do both. In my experience, they both together are smoother. Low end is just great. No need to dig to first at the parking lot.
Bomboasy
Bomboasy
Originally Posted by TampaMCS
Ok, after driving with it less than 24 hours, went back to stock and removed the VGS. It was too jerky on the street.
#47
MasterShaftner
09-04-2015 03:52 PM
09-02-2015 09:05 AM
