Drivetrain IC Airflow Question
#151
The experimenting continues
How I spent my 4th of July.
Well some of it anyway.
The GRS diverter fits OK as is but I wanted to improve it. The front upper lip sets just below the hood sheetmetal and exposes(on my car) the flat edge and I'm sure allows air over the top. Second I wanted room for more air and thought I knew where to get some.
To fix the first bit I needed to cut back the leading edge but I also wanted to bevel it to lead air in better. So first I built up fiberglass on the top which would allow me to remove material as needed from the bottom. The bevel and cut isn't quite finished because I didn't have any heavy grit paper for my sander so I just rolled the edge a bit with 220.
Next I removed a 9 3/4" x 7 3/4" section from the top of the diverter. I coated the bottom of the exposed part of the hood with painters tape. I next installed the diverter. Followed up with installing aluminum tape to form the new chamber.
My actual intent is to use this as a mold to lay in fiberglass. but for now what I have works well.
Based on sampling the depth across the indent I figured there's a 5/8ths" average depth. Using this I have close to 47 cu/in extra room for air. Check my math please. 9 3/4 x 7 3/4 x 5/8.
Using my normal method of cruise until temps level off I did some data gathering today Took measurements all around 2-2.5K RPMs at differeing speeds. Avg inlet was 133, avg. outlet= 105, avg. ambient = 93. Humidity in the 80s. Thermal efficiency is 70%.
Improvements to come.
#153
#154
Originally Posted by shankrabbit
Shiney.....
Thats looking real cool, Obe. I'm trying to get a grasp of how that sits on the IC. (that is the underside of your bonnet, right?)
Maybe I'm just too distracted by the shiney stuff.
If you look at this pic just imagine the part with the vendor information( sorry Graham) removed.
#156
Originally Posted by stevecars60
1 thing to remember is the engine moves, north & south, a little better than 3/8". So don't make anything fit too tight especialy over the radiator & the engine.
I've had the GRS over a year and had no issues with interference. The foam is getting a bit worn though.
I'm also running the Powerflex motor mount bushings so movement is reduced.
#157
I've done a few alterations to my original design because of that.
#158
#159
Still working on an under scoop. There are a couple of pics somewhere on this site with the IC plate done.
Obe, so how do you like the mounts as far as noise in the cabin, if any? Some have said there is a drone?
No audible cabin noise for sure. Vibration is quite mild at idle, a little more so with the AC running. At cruise or running hard you'd never know they were there unless you get a little sloppy with a shift. They then do a nice job of pointing out the lack of smoothness
I am only running the 2 large yellow mounts though so maybe someone running all 4 can comment as well.
#162
"I am only running the 2 large yellow mounts."
That setup is what I was thinking
Another deciding factor was that the sleeve in the smaller purple units has more clearance around the bolt than I felt comfortable with. This may or may not still be an issue.
#163
#164
IC mod
The lighter is for scale.
The under hood temps seem cooler since the bottom of the plate is open. It is in the mid 70s today however on cold days, low 30s, it still gets pretty toasty under hood.
I'll need to run some 30-40mph and 60-80mph tests for under hood temp. I have an Alta diverter on the way to do some side by side next week.
For now, it looks like it's working well.... For $12 worth of materials & 8hrs.....
#165
Nice
Took me a bit to figure out the hole in the top
#168
Originally Posted by norm03s
stevecars60, looks real good, I have my card board patterns cut out but haven't gotten past that, you beat me to it.
Right now the Alta diverter is on & it looks like the under hood temps are quite a bit lower than the stock unit.....
Obe needs to jump in with his result...
#169
snip...
Lot's of smoothing and blending.
Did go on a MINI run today though. Didn't log anything but did keep an eye on outlet temps and I'm more than happy with what I'm seeing. Nothing revolutionary but definitely an improvement over what I had before I started doing all the diverter mods.
I'm also going to play with some new materials for the seals. I have some closed cell foam that is a higher durometer rating than what is currently on the diverter.
The tinkering contunues even if it's just for the sake of tinkering.
#170
Obe, any under hood temp that is lower is a good thing. You may find that getting a good controled enviroment to test with is very hard. Key word - controled.
In this case, the under hood scoop, I'm looking for better air to the IC & #1 heat reduction under the hood. If #1 works, the rest will will follow. Bottom line, in this case, I'm using a simple gauge to measure under hood temps below the IC ( not much control but you can get a big picture average of where you are going )
#171
Been there almost done that. My cheap gauge only goes to 150º, my good gauges are the ones in the inlet and outlet boots. Carefully watching and measuring those 2 points will net me the information I need.
If you think about how thermal convection works temps for the air under the IC may actually rise if you're drawing more heat out of the IC at a particular flow rate. This is really the realm of a flow bench and not some gauge stuck under the IC that will be very much effected by the surrounding metal. You would really need to isolate just the air for proper measurements.
That said I've played with my cheapo gauge placement all over the engine bay. In a nutshell if you're going over 25 MPH you're pulling good air through the engine bay. It would be very hard to differentiate a tiny delta that could just as well be affected by head wind, tail wind, etc.
To me measuring I/O IC temps is the best I can do on my tiny budget.
One thing that occurred to me last night, very subjectively based on recent observations, is that I wish I had made measurements on a return to stability time.
Bear in mind I watch my I/O gauges a lot.....too much... and one thing I've noticed about my recent experiment is that thermal efficiency really hasn't changed but the system seems to recover better. To me that's very important. I cannot give data to support this so ...don't ask It is something to consider and may be something the DFIC does better than the traditional IC. Pretty tough to measure and compare though.
#172
"Bear in mind I watch my I/O gauges a lot.....too much... and one thing I've noticed about my recent experiment is that thermal efficiency really hasn't changed but the system seems to recover better. To me that's very important. I cannot give data to support this so ...don't ask It is something to consider and may be something the DFIC does better than the traditional IC. Pretty tough to measure and compare though."
This is the whole point, Air flow & efficiency. There's no doubt the DFIC is the best ( other than running your AC out there ) but as a whole, if the system recovers faster at, somewhat, low speed, it's a good thing & the experiment works.
The Alta diverter was on the car all day yesterday & it is a vast improvment over stock as far as recovery. Tomorow it will be hotter so I'll run the contraption. For a temp gauge I'm using an SW water temp, goes up to 280. The probe sits right at the D rear of the IC. The control is the hard part. accurate #s on different days....... still better than stock across the board
#173
#174
Originally Posted by MSFITOY
Under steady cruise state...I've seen the DFIC bring the temp down to under 10F difference against ambient...
I expect this can only get dramatically better after I install M7's new hood louvers later this week
Just a weeeee bit more expensive though I'm thinking and not a DIY.
Curious to see the results
#175
