Drivetrain Need some info from you Turbocharged/Twincharged "S" owners out there.
Thinking about getting a turbo kit for the "S". I've done a search, but there seems to be little info out there on the Turbo kits such as Alta's. How many of you have the turbo kit and what do you think of it? Waste of money? Or best performance upgrade out there? What other kits are avail? if there are any. Is there a kit for a FMIC on this set up? In Alta's site, they state "UP" to 400 HP, but don't say how much the kit produces right out of the box. What is the boost level of the kit? The description of the kit "performance wise" is very vague. Besides this post (Link below) is there any others you guys reccomend reading? Any info you can provide would be great....
Thanks.
https://www.northamericanmotoring.co...ighlight=turbo
Thanks.
Here's a thread dedicated to twincharging:
https://www.northamericanmotoring.co...ht=twincharged
Tonnes of stuff in there... enjoy!
Twincharging is the best upgrade hp per dollar. However the limits of the stock internalls is about 22-23psi. Which will make anywhere from 250 to 280whp.
After that you need to replace the pistons with forged pistons. Which will take over 400whp.
Do not use a 15% pully with a twincharge kit. I have chipped the teflon coating off of my rotors in my supercharger.
As far as all the kits go... They all are capable of making enough boost to break a ringland. However Alta has the "best" turbo as far as maximum power goes.
Originally Posted by Veni_Vidi_Vici
I suspect that someday the Alta kit will have serious advantages in support due to it's large numbers of distributers. Right now, however, their kit seems "half-baked" with no ecu available, etc.
Our tmap sensor (located on the intake manifold) is a 2.5 bar map sensor. Meaning that it can read up to 36.7psi. However that includese atmospheric pressure.
So subtract 14.7 from 36.7 and you have 22psi. If manifold pressure goes above this the computer throws a check engine light. When it throws this code the computer stops reading off of the tmap and relies on a "table" programed in the ECU. Not good sense it is programed for stock pulley size.
The tmap sends a voltage to the ecu depending on the amount of manifold pressure. It ranges from 0-5v. When the tmap sees 22+psi it sends 5v to the ecu. Which throws the code.
With a voltage clamp you make it so that at the most the computer sees 4.9 volts.
But here's the tricky part. If you are using an SAFC to tune the car. When you subtract fuel you are lowering the amount of voltage the ECU sees from the tmap. So to a certain extent the SAFC acts as a voltage clamp. I was able to do 27.8psi without maxing out the tmap.
In the ALta kit from the get go, you can safely run 16psi totally before you need to retune the air/fuel map. You set the wastegate so the max boost would be 16psi. Setting the wastegate isnt bad, but you end up just dumping a lot of boost. I went the route of adding in a boost controller to do setup, and pretty much shut the wastegate all the way. It gives me quicker turbo spool. I am currently running 23psi on stock internals at max boost & I am seeing around 280 to the wheels. When I dyno'd I ran 20 psi & put down 258. Since then all i have been doing is fine tweaking with my AFC & wideband gauge. I am setup to run a lot more boost once I replace the pistons, but that wont be till next year.
Honestly I think if you would just run the kit as it comes, you would prolly see around 200-225 hp at the wheels with no tuning.
Feel free to pm me if you have other questions that way you can give me a ring if you like to talk about it more.
Peace
Peace
Spank
11
04-09-2020 02:23 PM
Gil-galad
Eastern Iowa MINIs
63
11-17-2016 02:54 PM
