Drivetrain inter flippin' coolers
Originally Posted by obehave
Expense, installation complexity and the fact that they aren't really all that advantageous on a street driven vehicle.
They make a huge difference on the street. They virtually eliminate heat soak. Air-to-air intercoolers are only effective when air is moving over them. Water-to-air are constantly effective...I would say a water-to-air is more advantageous on a street car than anything.
Originally Posted by ThumperMCS
I disagree about that...
You just get a lot of hot water that actually takes longer to cool than an air to air.
Look into it.
on
Water to air intercoolers run a radiator to cool the fluid. You ain't movin' you ain't coolin'
Look into it.
Look into it.
on
Originally Posted by 1nf3rn0
Another problem with Water to Air intercoolers is that once they become heat soaked, they take a long time to become un-heat-soaked... In air to air, and more specificly, M7's DFIC, recovery from heatsoak is very quick to instantaneous.
Look into it.
Look into it.
are they taking the cores just for the end tanks or what? hopefully they're not just wrapping cooling tubes around the stock i/c and selling it back to the customer .the lack of finning gets me thinkin' that may be the case. wouldn't finning plus water tubes be the best of both ?picture a dfi/c but with water tubes as well .
Originally Posted by herbie hind
slow down ...i've sat in alot of trafic in boston in all kinds of radiator cooled vehicles. they still work better than none at all.look at the harley guy he just shut down for a while to cool his bike.
Here we go again!
The water adds mass. Takes longer to heat, takes longer to cool. Like everything else, it's a two edged sword. If you're a drag racer, they can be king! Fill the resivoir with ice water, and get much higher thermal efficiencies than any air to air. Depends on design, cost, and use.
One nice thing is that it's pretty easy to route the water flow to a radiator that is more optimally located than the IC on the stock car. And unlike FMICs, having the water take a bunch of turns doesn't sap power like having the intake charge run all over the place to get to an optimal IC.
Matt
Matt
Matt
Matt
Where would we be with out the Dr. to enlighten us like that?
Never even thought about that, but yeh, where do gintani and minimania mount the radiators for the W2A ICs?
Interior/Exterior Unboxing Video of Sneed4Speed R53 Brake Cooling Kit
Gremothra
09-09-2015 08:42 PM
