Drivetrain Redline MTL = synchro problem?
As my 03' Mini Cooper S is reaching 43K miles I decided to flush the tranny fluid. After reading all those good reviews on Redline MTL, I put it in. The old fluid was ... totally black without any red in it and new fluid was way cleaner.
As soon as I took it for a drive, I found both gear shifts and transmission were smoother I wondered why I didn't change it
However, after a few days since yesterday or so, I noticed that the car was slow to react to acceleration. My feeling is that acceleration right after upshifting has a big delay, the RPM seems to go up slower than normal, and the actual speed increases even slower. I suspect a synchro problem as the Redline MTL might be too thin and thus slippery for synchro to work properly. Shifting easier might not mean less wear but more wear, and bad on synchro.
How many of you have switched to Redline MTL? Can you give me some inputs? I'm thinking of flushing the fluids again back with OEM fluid as soon as I have an aswer. Thanks!!!
I'm not sure what you mean by slow acceleration. The syncros only work while your changing gears; allowing the gear teeth to engage each other at the same speed so they don't grind. Syncros have nothing to do with what happens after car is in gear. You can wear syncros by just pushing the clutch in while moving and start going through the gears. Every time you push the gear lever into a gear, the syncro must work.
Redline also makes MT-90 that's a 90 weight (instead of 80-85 like MTL) when hot.
Originally Posted by DR61
The symptoms you are describing have nothing to do with the transmission. Most likely boost-related. Bypass valve sticking?
Bypass valve sticking? Is there a way to check? Maybe it is just coincidence? I just don't want to take it to dealer and then it's the tranny fluid being too thin/slippery.
Originally Posted by pberry51mini
Or, if it was not doing the job of lubricating the gears sufficiently.
Are you sure there is sufficient oil in the tranny? Not that I think you're stupid.
I fiilled almost 2 quarts of Redline MTL tranny fluid until it overflew. I haven't seen any leaking on the floor so I assume it's sufficient oil in the tranny.
If I'm losing fluids, isn't it suppoed to make shifting harder? The shifting itself is still smooth and easier than with the original OEM fluid.
When I was racing showroom stock cars, we used Redline MTL to make the cars go a bit FASTER (reduce friction in the gearbox). However it did not make a difference one could feel. NO WAY 'thin' fluid could slow acceleration down.
Check this out:
http://auto.howstuffworks.com/transmission.htm
This article shows how a manual trans works. Syncros have nothing to do with power delivery between the engine and drive shafts; they only work during the time you are moving the gear lever. Gears transfer the power, and the gear teeth are always engaged.
UncDeo
11-04-2019 04:08 AM
mimaal
09-04-2015 09:09 AM
Manny_cooper
09-03-2015 05:48 AM
09-02-2015 09:05 AM
