Drivetrain How do "ECU" upgrades work?
Hi,
Just a few quick questions I am sure someone here can give me a hand with.
How do ECU "upgrades" for the Mini work? I have been doing some reading but am unable to find a definite answer (maybe one of the MTH or similar guys can pipe in here), here are a few thoughts I had.
1. Does the entire ECU get reflahsed eg: the software in the ECU is overwritten (similar to a BIOS being flashed on a PC), if this is the case is it possible for a ECU upgrade to change the version of your ECU software?
2. The upgrade simply "remaps" the ECU changing certain settings in the ECU but not modifying the actual software, if this is the case does that mean that ECU upgrades are independent of the software version of the ECU?
3. Are ECU "upgrades" diffrent for '05+ mini's due to the changes BMW made?
4. Also what scenario would cause the ECU "upgrade" to be lost eg: getting car serviced by BMW, etc.
Thanks for the help, I am looking to get the MTH ECU work done and I just wanted to make sure I had my facts straight
I'm not quite sure what you are asking... When you do more mods to your car, all you need to do is contact MTH to have them send you an updated piece of software for the current mods. If the dealer reflashed your ecu with an upgraded piece of software, you will need to upload this revised software from your ecu and send it to MTH for them to fix. You can not put a MTH file for an older ECU software version on a new one. (Ex. You had v29 (or whatever.. i don;t know what BMW uses for software numbers...) with mth, but the dealer flashed it with v31. You need to upload v31 with the OBDII cable and send it to MTH for them to make a v31 setp for your mods.
Hope that helped...
Blake
Hope that helped...
Blake
Hi,
No and no.
No, dependant.
Yes and no. It is a different ECU but the process it the same.
BMW/Mini reflash. If that happens just send me your file and I will send you a compatible MTH reflash.
No and no.
No, dependant.
Ahh yes, thats one that I forgot to ask.. as hopper asked are ECU re-sets safe?
Also on a bit of a tangent, should I reset my ECU (if its safe) after I have done all my mods?
The soft reset is of dubious value...
there is a ECU reset function where the ECU relearns a bunch of items (like analog voltages from position sensors when something like a TB is at the extremes of travel) but you can't get there without special software. The reset you can get to doesn't really do much other than flush the on-board computer and a few adaption values....
Matt
Matt
07-16-2020 12:54 PM
minimofo
12-26-2015 11:45 AM
