Drivetrain Shifter Nirvana
Shifter Nirvana
So, I now have a combination of the Mania SSK, which reduces throw by ~20% and a sweet JCM shift ****, which I've adjusted up to about 3/4" higher than stock. This is an awesome combination, imo. I've got the shifter up closer to the wheel and a reduced throw (I'm guessing around 15%). Feels about perfect to me. Click. Click.
The **** is comfortable in the MINI, whereas that would seem like it would be ungainly... In the m3, with the location of the shifter, that style works better....
I do like this more than a ball. Not more comfortable, but pushing/pulling against the straight sides seems to feel more... precise. I'd say the top of the shifter is about 1.25" in diameter.
In cars, most sequential gearbox shifters are of the simple "push away from you to downshift, pull towards you to upshift", and the gear lever is spring-loaded to pop back to the center position after each shift.
Scott
Motorcycle gearboxes are sequential, to give you an example. From any given gear, you can only shift to the next higher or lower gear - no skipping past gears.
Scott
Scott
Here's a link to a page describing BMW's SMG-II Sequential Manual Gearbox:
http://www.toodarkpark.org/misc/cars/m3/smg/index.html
Mercedes and Fiat also have similar setups, with different names.
Scott
Scott
RobbyD
01-29-2019 01:22 PM
MINI Stupor
10-01-2015 11:36 AM
