Drivetrain Changed Bypass Valve
#26
You are right !!!
My boost (although it took longer to get there than I remembered) was the same just shy of 15 lbs
But my vacuum right before the BPV change was never more than about 4 lbs
What ever happened to my orig BPV would not allow a adjustment that would have the butterfly fully closed.
After= Boost still just under 15 lbs of boost (I do think quicker to get there)
and vacuum now 12 at idle and almost 20 on coast down
#27
You are right !!!
#29
#30
i personally wouldn't think so as your cylinders determine vacuum. so likely you'd test vacuum at the intake manifold. the bypass would be pulled open by this vacuum.
#32
The reason I asked is that happened to me last weekend. Idle vacuum changed from 18 in to 4 in hg and max boost peaked at 5 psi (was 15 psi). I am still trying to determine the cause and thought it might be the BPV.
#34
Those are exactly the sypmtoms....
Matt
#35
You were right, it was a leak. The hose to the fuel pressure regulator was off. That was a much easier fix than swapping the BPV. All is good now.
#36
i see where y'all are goin' with this but if vacuum pulls the bypass open isn't it a mute point once it starts to open ?
#38
see this is where i get off. the hole in the tube for the vacuum sorce on the bypass valve is below the butterfly of same when mounted; so it's vacuum sorce toopen is all the way round through the s/c . so this coming summer i'm taking the front end off cause of an oil leak and you can bet some gaskets will be getting replased as well as a thorough inspection of all the mating surfaces of everything on this path. so how much should it be open at idle ? maybe this is the sorce of alot of the troubles; it's not very consistant.
iamcamkeenan
08-10-2015 03:31 PM
