Drivetrain Improved belt tensioner
I am currently running the 19% pulley and am on my 3rd belt. Each time the belt breaks the belt tensioner slams into the crank pulley...destroying it (3rd crank pulley too). I am going to install the mymini tensioner limit stop tomorrow as well as a new belt tensioner assembly but I was wondering if anyone has seen any product to replace this poorly designed belt tensioner. If you have seen Ryephile's belt tensioner on his turbo only setup this is kinda what I am looking for.
on
I have the GT Tunning Tensioner limit stop:
Which is very similar to the MyMINI stop. I have lost one belt while driving and the limit did its job. I had belt all over the engine bay, but the tensioner pulley did not crash the crank pulley.
I highly recomment it!
Mine's from Myminiparts and it looks exactly like this one...guess the "patent pending" doesn't apply to over seas...
Which is very similar to the MyMINI stop. I have losted one belt while driving and the limit did its job. I had belt all over the engine bay, but the tensioner pulley did not crash the crank pulley.
Hmm. That stop plate looks like a good idea.
Does the tensioner assembly have a "service life"? ie, should it be replaced at X amount of miles? I ask because I have about 93k miles on the car,60k with the 15% and 45k or so with the 15% and the 2% crank. I'd hate to sieze the tensioner pulley!
Thanks!
Jim
Thanks!
Jim
on
Thanks!
Jim
Thanks!
Jim
Two weeks later, one of our members with fewer miles snapped his belt while we were at MIS...he got two laps in and was flat bedded home
Check your belt and tensioners ladies...flat beds are expensive
I thought factory belt was supposed to be able to make it 60k.
Thanks All!!
Jim
I know I know...I was surprised my tensioner was going south...it's cheap insurance to check/replace these parts...belt or tensioner goes, no alternator, no water pump, walk...sucks flat bedding miles away from home...
can you imagine what the regular *** paysto have this stuff done perodically at what 100.00 an hr?!!!wow!!impatient:impatient
I must have installed/uninstalled this thing a million times. I eventually just threaded a bolt in from the backside where the slotted end of the stop will go, and used a lock nut.
Park the car with wheels cranked to the right
Remove the four plastic expanding rivets in the fender liner, three in front, one on the inside
Remove the philips head screw directly above the tire, use a stubby screwdiver
Remove the philips head screw that holds the front of the fender liner, it's a little to the right of the fog lamp area, under the bumper cover, use the stubby here too
Gently pull the fender liner away from the body and around the sensor wire
You should be able to see and access the front bolt for the tensioner "shock" the rear one can be reached from behind the engine.
on
That's my tensioner in #3. I put mine on while I was replacing the crank pulley. It is not required to remove the tensioner to put the limit stop on, but I also added the GT Tuning tensioner and idler pulleys at the same time. I figured while I had it apart, might as well get it all done.
