Drivetrain oil catch can
oil catch can
I have read up on the oil catch can for my 04 MCS, but i was wondering what kind of reviews the Oil catch can has got. My MCS has 80,000 on it so I wouldn't be surprised if there has been oil buildup in the IC. I would like to know the results from the install, good or bad. is it worth the purchase?
i can tell you from experience that the oil catch can is effective in catching oil that is in the intake system. however be sure to empty the can on a regualr bais. becasue most people don't realize it but there is also water vapor in the crank case and the water will also collect in the oil catch can. and if you live in an area where it freezes often in the winter time it can freeze the water in the catch can and create positive pressure in the crank case. on the car i saw this happen to the pressure cracked the vavle cover and sprayed oil on tyhe exhaust and caught on fire.
again i'm not trying to scare ya form the oil catch can system i just want to warn ya of what could happen if not attended to.
on
OCCs do work, I don't think anyone will argue that here. OCCs are more about increasing engine longevity than anything else. I think its more of a question of mod priorities and $ value. Clearly, its not a must have but a nice to have.
As to the problem of water freezing and creating a pressure issue - for that to happen the OCC would have to be full = neglectful maintance. While OCCs size can vary most have a way to monitor how much is in the can.
occ
Exactly correct about the vapor/water buildup. You MUST check the can at least every month in the winter. (Chicago). The can freezes all of the vapor and holds very little oil after 29k miles. If you are willing to ADHERE to a schedule...and drain the can even after the 22nd day below freezing for a high...it might be for you. For me I would not do the mod again. Just not enough oil to scare me has been trapped...but plenty of the clear stuff to discourage. I vote NO.
Depending on how you have the hoses hooked up, you will either catch oil or water.
This routing has proven to catch oil and work. I recently pulled by DFIC off and there wasn't even a *odor* of oil in it!
cheers
another option?
Hi guys,
I'm installing mine now and I have two questions:
1.) Is it worth it to install a cranckcase vent filter on the line (short green line in Dr. Phil G's diagram) coming out of the driver's side of the valve cover and cap off the inlet on the intake hose? I had a normally aspirated Saturn coupe before and this was the preferred setup there from a performance standpoint (no burning of oil vapors from crankcase)... environmental considerations aside of course.
2.) Can I use the rubber hose from alta to attach to the grey line from the SC or will it collapse (blue line in Dr. Phil G's diagram)? If the rubber hose is no good, what's a better solution?
Thanks!
Thanks!
Hi guys,
2.) Can I use the rubber hose from alta to attach to the grey line from the SC or will it collapse (blue line in Dr. Phil G's diagram)? If the rubber hose is no good, what's a better solution? .
Thanks!
Thanks!
molala
10-02-2015 01:53 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
09-10-2015 12:34 PM
09-03-2015 03:01 PM
09-02-2015 09:05 AM
