Drivetrain DIY intake: cutting a hole through the back wall
Old 10-19-2010, 10:11 AM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
IF you look at the bottom of the air-box, it has a few vents to let water that gets into the air-box out....
Folks with CAI have been removing the plastic panel (separating the firewall/engine compartment), or cutting holes in for a long time (Swiss cheese Mod)....
IF you get the Dinian CAI it has a snorkel that get air from the opening at the base of the window...(or the JCW has a flap that opens...often locked open or removed), it has an additional hole to let more air in...same idea as cutting a larger hole in the firewall panel/back of the air box. Since the stock filter is so bad...a panel filter is a must if you mod the factory stock box....
That having been said...a CAI is pretty cheap...and will do more...but for a super cheap mod to get a bit more...from a stock car.....this might do a bit...
  #27
Old 10-19-2010, 03:33 PM
ACallahan's Avatar
ACallahan
ACallahan is offline
I just took a soldering iron and melted about 10-15 1/2" diameter holes in the cowl adjacent to the end of the K&N filter, seems to work great getting that extra air in the box, and took all of 5 minutes to do.
  #28
Old 10-19-2010, 03:47 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
Lots of folks remove the entire panel...you can also buy them with the holes precut...kinda $$$, but simpler for some I guess who are afraid to rip it out.
surfblue
10-24-2018 01:20 AM
Mini'mon
08-16-2015 12:47 PM
eliseo1981
08-06-2015 05:00 AM
Quick Reply: Drivetrain DIY intake: cutting a hole through the back wall
