Drivetrain Turbo-back exhaust; not all roses
#26
The dip in the low end with the aftermarket exhaust.. Looks like the ECU is pullings some timing on both stock and aftermarket exhaust.
You can see that boost spike at the end of the graph
. I hope someone makes a harness for a piggyback system to clean that torque/power up. It would control all timing and fuel once boost is built with the ecu controlling everything underboost, a stand alone would be costly but more resolution in tuning.
![No](https://www.northamericanmotoring.com/forums/images/smilies/no.gif)
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
Give me some time play with this car a bit, but most important a way to control the ECU's timing/A/F (i.e AEM, HKS Fcon, UTEC) is needed to safely start exploring with this engine. Reflash is not going to cut it.
![Nod](https://www.northamericanmotoring.com/forums/images/smilies/nod.gif)
--Dan
Mach V
FastMINI.net
#27
Huh? The car has a bypass valve as factory equipment. Why do you want to add a blow-off valve?
I was just looking a my wifes car and it is revented / w internal wastegates. We have seen significant intake temp drop with a vent into atmosphere system over stock "revented" on other turbo applications. I prefer VIA over resurculate.
As has been mentioned several times (see my dyno results, too), the dip in the low-end torque is from a drop in BOOST. It's not related to timing.
So does anyone know why the ECU is causing this? A aftermarket Booster controller maybe a fix?
It looks to me like this ECU is pretty sophisticated. It's unlikely a standalone is going to have more resolution than the ECU itself.
I disagree on this as the high end standalones ECU have great knock sensors HKS Fcon V pro to name one. However if the stock ECU can be reprogramed "tuned" then you just cant beat the stock ECU.
With a good ECU programming solution, timing and fuel can be controlled inside the stock ECU code. Of course, I haven't yet SEEN a good/useable ECU programming suite for the R56, but we'll get there.
I agree, but thats just it there isnt any at the moment.
--Dan
Mach V
FastMINI.net
--Dan
Mach V
FastMINI.net
#28
I'd pesonally be wary of a generic knock sensor, especially one designed for port injection engines of who-knows-what cylinder count. The R56 MCS's engine being direct injection really changes the whole tuning game. AFR targets are different, timing targets are different. I'm not saying it's impossible, but Dan is right, the DI-Motronic is state-of-the-art in most instances. It's also annoying that there are currently no ways to tune it. Companies like Revolution MINI Works, Mynes Performance, and Lucky Dog Garage have the means to write R53 ECU flashes with excellent sophistication, however being the R56 is totally different caps their current ability for R56 owners, unfortunately.
Piggy-backs may be useful in the meantime, but without an ECU pinout, and several layers of sensors being implimented, cleanly using piggy-backs to do what we're really trying to do may be prohibitivly difficult.
As for the big question related to this thread "Why is the ECU changing boost?", that is still alive and being determined.
That's my take,
Ryan
That's my take,
Ryan
#29
First off, SCHWEET setup! I hope you wont mind me nosing around your car at MOTD.
As for the boost reduction, could it be from a resonance during low rpms? Or perhaps something centered around the VVT programming and markedly reduced backpressure? There is no timing pull going on, is there? Since I have yet to learn much of anything regarding specific operation of the newDI FI system and all the new hardware, I guess I am just talking outta my exhaust pipe for now.
#30
I am curious if the guys at Vishnu Performance can help us out on this. They developed a "black box" for the 335i TT. It seems that in essence we have the same engine but 4cyl and 1 turbo. THey are laying down a 75whp improvement and 80lb ft of torque to the ground. If you dig around on bimmerforums and read what they figured out about the ECU it is quite interesting.
The ECU has 16 channels and they decided to only use 4 so the others can be modded to include gear specific boost levels. launch control, etc. pretty sweet. The box modifies the variables past the ECU so the car thinks it is running stock levels. $1365 for 100hp and 100lb ft sign me up if it picked up the MINI 50HP would be killer
#31
--->Greatbear: I hope to see you next weekend! Of course you can stop by and check out the new MINI!
As for your suggestions, the resonance theory may be the strongest yet, right there with the question of how the variable intake timing is controlled. No, the timing curve is very similar from stock to post-exhaust, as is the AFR curve, so those two seem to not be in-play with this situation.
--->RR56: Oooh an XEDE application for the R56? That would be very nice. Vishnu probably does have a leg up on most being that they've sunk their teeth into the very similar 335i. Both the 335i and the R56 MCS use 10.5:1 static compression ratios with tiny turbos and Bosch DI systems. The few differeneces are stock boost levels, and of course cylinder count and displacement. Oh yea, the 335i also uses "2nd gen" injectors that are in the center of the combustion chamber instead of offset like the MINI's "1st gen" positioning.
Should I call Vishnu, or can someone local with an R56 contact them and be willing to let their car be the guinea pig? I'd do it if I was in Cali!
![Grin](https://www.northamericanmotoring.com/forums/images/smilies/grin.gif)
#33
#34
On what application did you see a "significant intake temp drop with a vent into atmosphere"?
#35
#36
However his comments are perplexing:
The excessive pressure that is relieved by a wastegate is NEVER routed back into the intake tract. It is either vented to atmosphere or routed back into the exhaust.
I don't think anyone with a background in cars could possibly make the mistake of confusing a blowoff/bypass/diverter valve with an internal wastegate. That being the case, I'm stumped by what he's trying to say.
#38
I have been modifying cars for years as well.
He begins by talking about internal wastegates, then goes on to mention that he's seen a drop in intake temps with a vent to atmosphere system.
Acompressor bypass vavle also known as a compressor relief valve is a vacuum-actuated valve designed to release pressure in the intake system of a turbocharged or centrifugally supercharged car when the throttle is lifted or closed. This air pressure is re-circulated back into the non-pressurized end of the intake (before the turbo) but after themass airflow sensor.
A blow off valve does basically the same thing, but releases the air to the atmosphere. This creates a very distinctive sound desired by many who own turbocharged sports cars. Some blowoff valves are sold with shaped exits thatmake the "Psshhhh" sound, these designs are normally marketed towards the tuner crowd. For some owners this is the only reason to fit a BOV
Downsides of releasing air to atmosphere
The unique sound caused by a blowoff valve (but not a compressor bypass valve) sometimes comes at a price. On a car with amass airflow senor, doing this confuses the (ECU) of the car. The ECU is told it has a specific amount of air in the intake system, and injects fuel accordingly. The amount of air released by the blowoff valve is not taken into consideration and the engine runs rich for a period of time. Engines with a manifold absolute pressure regulated ECU are not affected.
Typically this isn't a major issue, but sometimes it can lead to hesitation or stalling of the engine when the throttle is closed. This situation worsens with higher boost pressures. Eventually this can foul spark plugs and destroy the CATs (when running rich, not all the fuel is burned which can heat up on and melt the converter).
How it works!
A blow-off-valve is connected by a vacuum hose to the intake manifold after the throttle plate. When the throttle is closed,underpressue develops in the intake manifold after the throttle plate and "sucks" the blowoff valve open. The excess pressure from the turbocharger is vented into the atmosphere or recirculated into the intake upstream of the compressor inlet.
A wastegate is a valve that diverts exhuast gases away from the turbine wheel in a turbocharged engine system. Diversion of exhaust gases causes the turbine to lose speed, which in turn reduces the rotating speed of the compressor. The primary function of the wastegate is to stabilizeboost compressor pressure in turbocharger systems, to protect the engine and the turbocharger. The wastegate is controlled by a wastegate actuator.
I will add more info on the internal wastegate, but I have to run now. From now on I will be the only one that will post using this user name. Once again sorry for the confusing posts. Bye the way I dont use smiley faces. Mr Wata good job sounding off and watching out on info being put out.
#40
#41
![Smilie](https://www.northamericanmotoring.com/forums/images/smilies/smile.gif)
#43
#45
#47
Hi Guys,
Thanks for your interest. For what it's worth, we've already started our R56 PROcede development. Given that the Mini and he 335i share a lot in common, I don't think it would take very long to have a PROcede application ready for you guys. Give us a 2-3 weeks and we should have some initial results for you. A few weeks ago, Dustin@Vishnu and I "borrowed" a Mini from our local dealership for day to conduct all the necessary sensor testing and waveform logs. Everything looks reasonably conventional. Most of the work we've done with the 335i should apply directly. We'll be purchasing our Mini this week if all goes well. We're very excited about the car as things look very promising.
Cheers,
shiv
www.vishnutuning.com
ps. We'll see what's involved with becoming a vendor here
Cheers,
shiv
#48
PICS:
--->jlevy: I'm not sure if I snapped any pics of the turbine exit. The compressor and turbine wheels are tiny. The turbine exit has this chamber where the wheel exducer combines with the wastegate flapper. The chamber has some decent volume to it, then it necks down to a 2 5/8" opening for the flange to the downpipe. The stock downpipe is not double wall; the upper portion is two stamped sheetmetal pieces welded together, and after the cat is standard tubing.
Cheers,
Ryan
Cheers,
Ryan
#49
Thanks J for posting those pics! Looks like that engine wasn't even ran yet by how clean that turbine side is!
--->RR56: Wow awesome! Glad to hear you got some feedback from them, and even better that the R56 is their next project. I really look forward to hearing what they pull out from their goodie bag.
#50
good job, it kinda makes me wonder how you can get higher boost without tweeking the ECU. i guess we need to dig the Bosch management system but reall does not make sense to me. Have you checked your EGTs? K03 is a pretty decent turbo, it will not hold boost, will peak up to 15-16 range and then drop to 12 and hold it, which is one of the biggest lack of it.
Again, I am puzzled with the boost changes due to an exhaust set up.
