E-Mini Wheel size impact on range
My Signature model with the 16" wheels went over 140 miles in my range test with city driving. Now I'm starting to see why.
Mini also has a 15" wheel that will probably clear the tiny brakes on the SE. It is 15x5.5 so it is the same width wheel as the BMW i3s (same motor) and weighs around 15 lbs. I bet it even helps 0-60 too because of the lower weight.
Oh, my 0-60 tests in sport mode with traction control off are usually in the low 6 second range and I did manage a high 5 second pass once too.
Smaller wheels for the win!
The following 2 users liked this post by Jon Roberts:
Clutch Wotan (11-11-2020),
eMINIman (11-11-2020)
