Electrical O2 simulator experience??
anyone tried using the o2 simulator from o2simulator.com for the mini application? did it work for you? did you leave the rear o2 sensor in? how was it wired and how long has it been in your mini cooper s ?
what year was your S? i have a 2002 MCS and want to use this product.
help any ideas???
help any ideas???
Both my son and I run the o2 sim ...
We run "test pipes" when at the track..
Mine has been in for 2 years.
If i am at the track I have never got any codes. If I happen to not put the cat back on, and drive very "calmly" on the treet i still sometimes get the code for "cat below threshold"
My son threw a code only twice right after install then none
Instructions with the unit and on line are good
online instructions??
well that doesn't sound to good to me. i have an alta header and the cat has failed with only 300 miles on it two days before my emissions is due
so i need something to get through untile i can replace it!!
i need all the readyness codes on the ecu to be there and no emission related codes. such as the cat ineff code p420 that i was getting. so i'm in a bind. my reg was due the 16th of the month. i can't throw a code period!!
so i need help!!
-john
so i need help!!
-john
what header are you running?
I run a now MIDIFIED MM header (with flanges to bolt / un bolt) the test pipe, High performance CAT that came with the cat, OR the OEM CAT
So 3 options for me.
I went through 2 cats from MM and that WAS a mess !
Y son is OBX with a flange for test pipe or OEM cat.
I have a OEM header and am sure that you may even be able to borrow one
You can use mine but you would need to pay shopping to an BACK to me.
I am in CAL, and know that if you PAY and submit the paperwork you do have a grace period and wont get tags untill you are smoged ...
sniffer test
-john
o2 sim
No problems with mine John and I have been running for a year and a half. Yes you can keep the o2 in. I have mine in and no issues with or with/out my cat but I can honestly say the turbo spools much better without the cat and that is a highflow 300 cell metallic race cat.
thanks, john
Is the o2 sensor in the exhaust? do you have a cel light on? If so then it might fix it NOT saying it will.
10-01-2015 12:34 PM
10-01-2015 12:34 PM
10-01-2015 12:28 PM
10-01-2015 12:28 PM
10-01-2015 12:13 PM
