Electrical Radar Detector
Radar Detector
Radar detector hardwired. If anyone wants to follow the same path, here goes:
1. Dug thru collection of old AC to DC batter eliminators (like for CD players, radios, cell phones) and found plug and wire that fit radar detector. Radio Shack sells the parts, but this was easier and smarter looking plug connection.
2. Ran wire from radar detector, across dash and down side of moulding on the drivers side. Moulding has 1/4 inch gap so easie to tuck in with no modification. Finally slipped behind moulding and thru back side of inside fuse box.
3. Here's the trick, Radio Shack sells a small brass terminal that wraps around one of the pins of a spade type fuse and slips into the fuse box right next to the fuse. The insert is constructed to actually wrap arond the spade pin on your fuse. This makes it too thick to slide into the tight fuse box, so I trimmed one side of the "insert" off with wire cutters. The backside of the insert has a standard wire connector fitting that you can clip unto with a standard solderless connector.
4. I selected a 5W fuse location at the very back of the fuse box (closest to engine). Use an ohmeter and check for two things. First, you want a fuse that is switched on and off by the ignition switch. Second, you and to slip the spade insert into the "dead" side of the fuse. This will ensure the fuse provides protection for your radar detector.
5. I split the newly ran wire with the color coded (positive) side to the fuse box. I added a solderless female terminal and slipped it onto the male "insert" that is now in the fuse box.
6. A solderless forked connector was added to the "ground" side of the wire. There are several convenient ground locations nearby.
That's it. Total time: about 30 minutes. Now Radar Detector wire is out of the way. The cigarette lighter is available for cell phone or whatever.
The insert to the fuse box is easily removable if you are squeamish about modifying your new Mini. Have fun!
I don't know about the rest of the nation, but in Southern California, most law enforcement agencies are now using laser rather than radar detectors, so keep that in mind.
Also, when law enforcement runs laser and/or radar guns they don't keep them on continuously. They have to visually estimate your speed first then use the laser/radar gun to confirm their estimation, so your detector wouldn't do you any good. Save your money and just watch your speed.
You're pretty much boned when it comes to laser; the V1 has a laser detector but, like other laser detectors, it only gives you a "should I stay or should I go, now" proposition.
With radar, if you're *smart*, you can use the radar gun's target-practice-with-birdshot properties to your advantage. You need what I call a canary, someone ahead of you that will get the cop's attention before you're in sight. A high-sensitivity detector like the V1 will give you plenty of warning when the OTHER guy is illuminated. Take a stopwatch and hang back, keeping other cars a ¼ mile ahead of you (which is pretty far at the upper limits of freeway speeds). Slow down when the other car gets painted.
There's an article on Gizmodo written by Alex Roy of Gumball fame who discusses the basic premises behind using a radar detector.
Remember, it's not a "cop detector", and it isn't a gimme. You've gotta use your brain with it if you want to play the supra-legal speeding game, and otherwise use it to keep The Man from putting his jackboot on your neck. ;-)
Get a Phazer from Rock Mountain radar. It will jam laser.
www.rockymountainradar.com
Ive had one for over 5 years and never gotten a ticket. Even tried it on my old laser unit before I retired.
However, even my small town now has a ladar unit so it is more up to common sense to avoid the ticket -- caution over crests of hills, not being the speed leader, etc. I will lament the decline of people on the other side flashing the brights to warn of smokeys...
