Electrical Driving Lights
Driving Lights
I finally got aroung to mounting my hella 500's driving lights. They are installed on coustm mouts. Everything went fine except when I tried to aim/adjust them. They were on for about 15 minutes and then the fuse on the lead going to the battery blew out. Any suggestions as to why this might of happened? They are wired just as the instuctions say with one exception, I didn't wire them to the high beams. The wire going out of the rocker switch ( which was supposed to be tapped into the high beams) goes the fuse box and using an addafuse is tapped into an always hot fuse.
Those are really nice. I have a similar setup with custom mounts, but mine are mounted in the cooling holes just above yours, and are bolted into backing plates instead of drilling. I may consider your method for some fogs. Would you mind giving any measurements for the size of your brackets?
Ok it's been a week. The bumper shell came off again, all wiring came out of the bumper, and was inspected vigorously for cuts or crimps. To my surprise every inch of wire was fine, so I mounted the lights and hit the switch, and once again the fuse blew. The glass tube fuse supplied by Hella was only 1 amp, so I tried a 2 amp, 5 amp, 10 amp, and finally a 15 amp which did not blow.
As far as the brackets go they are 3" by 3" aluminum, I have enough material to cut up about 20 sets of these brackets. If anyone is interested let me know. Act quick as I'm flying out to Europe on Thursday for 2 weeks.
Since this thread is centering around the subject of driving light brackets, has anyone seen or done an application (aftermarket or custom) where the brackets protrude in the space between the top of the bumper and the edge of the bonnet?
I'm seriously considering the above-bumper driving lights mod (stimulated by the excellent example and guidance posted by ImagoX) but will probably not do it if it means having to cut holes or slots in my black mesh grills (w/Aero Kit). Theoretically, it seems like there's enough of a gap to accommodate a bracket of sufficient mass to prevent vib and jitter in the lights.
Any pointers?
Any pointers?
Here is a closer look.
Drive into the light
I have a homemade set-up like "twistysister". The brackets mount on the hood. The light bar, which is black and flush with the grill, has long bolts that go through the grill and mount to the bracket. The lights do not stick out past the front bumper. When the bar is not installed, you see nothing but the Mini nose. The lights are 100 watts "Eagle Eye" cheapo's from JC Whitney($40/set) but give off 380,000 candlepower/set. They worked great at night while on the Dragon. Whenever our group went out at night they always put me in front.
From the pics I can't tell where the the mounts pass through the bumper cover...the location you have yours is wher I am considering mounting mine. How did you attach the brackets to the bumper?
Looks great, but it looks like your support brackets pass through the bottom slot of the grill piece. I don't think I can accommodate this approach with my mesh Aero grills -- I sure would like to avoid cutting into them if possible.
Sorry about the delay, had to help my sons with homework etc. The 1/2" threaded studs pass through the bottom slot of a standard grill. I don't know if it will pass through a mesh grill with out cutting. I also, have added a small diagonal strut to keep the light bar/hood from vibrating. And yes, please be careful when driving at night, "deer" tend to attact Mini's driving lights. Does anyone have those deer whistles? Do they work?
