Electrical Hella 500 - Blown Fuse???
Old 11-13-2007 | 11:43 AM
MNEEME's Avatar
MNEEME
Ok need some help here.
I had my driving lights on and was trying to aim them and they turned off. Headlights are still function so I'm guessing I blew the fuse somewhere in the relay provided by Hella. Anyone know which fuse I need to replace? And what AMPS it needs to be replaced with.
Thanks in advance.
Old 11-13-2007 | 11:52 AM
MNEEME's Avatar
MNEEME
UPDATE:
The fuse that blew was the hot wire coming from the battery. It is the in-line fuse that runs from the battery terminal to the relay.
What AMP fuse do I need?
Old 11-13-2007 | 11:54 AM
Motor On's Avatar
Motor On
It should say on the fuse itself, other wise I can run out pull mine and check for you.
Old 11-13-2007 | 11:56 AM
MNEEME's Avatar
MNEEME
Ok Hella 500 Wiring Diagram -
That means I need a 15 AMP fuse correct? This is the red wire coming from the battery to the relay. Am I right? Anyone please.
Old 11-13-2007 | 11:59 AM
MNEEME's Avatar
MNEEME
The fuse says F15A250V - So that means 15 AMP fuse correct?
Why did it blow in the first place though?
Old 11-13-2007 | 12:05 PM
Motor On's Avatar
Motor On
15Amp 250Volt
What are you using for the ground? Are your connections to the relay tight? Where does the fuse itself sit? I lost one fuseas a result of the relay getting moisture and shorting things out. One fuse and eventually relay (took a little longer to sort that one out) later they work flawlessly.
Old 11-13-2007 | 12:08 PM
MNEEME's Avatar
MNEEME
My mounts are attached to the bumper brace which is where I connected my ground. I think it shorted cause I used quick disconnects and my ground touched my positive line cause they weren't taped off. They are taped now but I need a new fuse. DOH! Would that be why they the fuse blew?
PsychoRallye
21
02-17-2019 07:08 AM
mni928
11-09-2015 08:38 PM
BackcountrySkier13_inAZ
10-14-2015 07:00 PM
silence2-38554
09-28-2015 01:19 PM
Quick Reply: Electrical Hella 500 - Blown Fuse???
