Electrical wiring diagram for aftermarket alarm, 04 mcs
i dont know if this has been posted, but i looked on this site, which has almost any wiring diagram you need, and go figure, they only have the 07 mini cooper.
http://www.the12volt.com/installbay/....asp~TID~91986
i dont know if its the same, thats why im checking with you guys.
the alarm will be a Viper 5002 (2 way alarm/keyless entry)
id get remote start, but its manual, so i dont want to take the risks.
anyone else installed an aftermarket alarm on their r53?
I need this info also so if you would be so kind as to forward it to me it would be greatly apreciated!!! (Mines an 03 but the alarm / remote start related wiring should be the same)
12 Voltsred (x2)(common 50A)+ignition harness
Second 12 Volts
Starterblack/blue+ignition harness
Second StarterN/A
Ignitiongreen+ignition harness
Second Ignitionpurple/black+ignition harnessThird IgnitionN/AAccessoryN/ASecond AccessoryN/AThird AccessoryKeysenseN/A
Data BusCan Bus HighCan Bus LowCan Bus SwPower Lockyellow/red-GMCU, blue plug, pin 44Meter this wire while pressing the door lock switch on the center dash. The GMCU (General Module Control Unit) is in the passenger kick panel.Power Unlockyellow/brown-GMCU, blue plug, pin 42Meter this wire while pressing the door lock switch on the center dash. The GMCU (General Module Control Unit) is in the passenger kick panel.Lock Motorblack5wiGMCU, black plug, pin 9The GMCU (General Module Control Unit) is in the passenger kick panel.Driver Unlock Motorblue5wiGMCU, black plug, pin 20The GMCU (General Module Control Unit) is in the passenger kick panel.
Passenger Unlock Motorblue5wiGMCU, black plug, pin 38The GMCU (General Module Control Unit) is in the passenger kick panel.Parking Lights (-)black-GMCU, blue plug, pin 27The GMCU (General Module Control Unit) is in the passenger kick panel.
Parking Lights (+)each controlled separately
HazardsTurn Signal (Left)blue/green (F), blue/green (R)+GMCU, white plug, pins 16 and 18The GMCU (General Module Control Unit) is in the passenger kick panel.Turn Signal (Right)blue/brown (F), blue/brown (R)+GMCU, white plug, pins 5 and 8The GMCU (General Module Control Unit) is in the passenger kick panel.
Headlightwhite-GMCU, blue plug, pin 6The GMCU (General Module Control Unit) is in the passenger kick panel.
AutoLights
Reverse Lightblue/yellow+kick panel, harness to rear
Left Front Door Triggerbrn/gry/yel(D), brn/gry/yel(P)-GMCU, black plug, pins 22 and 42Use both wires and diode isolate each. The GMCU (General Module Control Unit) is in the passenger kick panel.Right Front Door TriggerLeft Rear Door TriggerRight Rear Door TriggerDome Supervisionbrown/yellow+GMCU, black plug, pin 7The GMCU (General Module Control Unit) is in the passenger kick panel.
Trunk/Hatch Pingray/brown-GMCU, black plug, pin 6The GMCU (General Module Control Unit) is in the passenger kick panel.Rear Glass PinHood Pinpurple/green-GMCU, black plug, pin 40The GMCU (General Module Control Unit) is in the passenger kick panel.
Trunk/Hatch Releasegray/brown-GMCU, black plug, pin 24Meter this wire while opening the hatch from the handle on the hatch. The hatch release motor wire is gray/green (+) at the GMCU, black plug, pin 2. The GMCU (General Module Control Unit) is in the passenger kick panel.Trunk Release MotorFuel Door ReleasePower Sliding Door (Left)N/APower Sliding Door (Right)
Factory Alarm Armblue/red-GMCU, black plug, pin 21Meter this wire while turning the key in the driver door key cylinder. This wire will also lock the doors. The GMCU (General Module Control Unit) is in the passenger kick panel.Factory Alarm Disarmwhite/black-GMCU, black plug, pin 3Meter this wire while turning the key in the driver door key cylinder. This wire will also unlock the doors. The GMCU (General Module Control Unit) is in the passenger kick panel.Disarm No UnlockTrunk Alarm Shunt
TachometerNOT red or red/stripeacignition coil or any fuel injector
Second 12 Volts
Second StarterN/A
AutoLights
he, man, Im wandering if the Mini Cooper S 02 is the same as the MCS 04?
And thanks for sharing .
07-16-2020 12:54 PM
Wohnson89
06-10-2020 04:53 AM
Navigation & Audio Aftermarket In-Dash Navigation
kitty90034
Navigation and Audio
08-25-2015 12:47 PM
R50/53 Replacement AC compressor??
PrimePower
08-16-2015 06:29 PM
