Electrical Front fog lamp bulbs
Old 05-11-2012, 03:11 PM
SMOG's Avatar
SMOG
SMOG is offline
LaminX covers on Hella Fogs
If you remove the OEM Fogs you probably can get the LaminX to conform to the domed shape of the OEM's with some gently heat. Nokya Hyper yellows in the OEM's. The photo is glaring out a bit and does not show how yellow the OEM's really are with the Nokya lamps.
Attached Thumbnails Front fog lamp bulbs-img_0001.jpg   Front fog lamp bulbs-fogs.jpg
  #377
Old 05-11-2012, 06:34 PM
JPR18's Avatar
JPR18
JPR18 is offline
If you remove the OEM Fogs you probably can get the LaminX to conform to the domed shape of the OEM's with some gently heat. Nokya Hyper yellows in the OEM's. The photo is glaring out a bit and does not show hoe yellow the OEM's really are with the Nokya lamps.
I might pick up some Hella 500s down the road...what brackets are you using? (for the grille mounted ones).
Has anybody used Lamin-x on the stock fogs?
  #378
Old 05-11-2012, 07:27 PM
SMOG's Avatar
SMOG
SMOG is offline
The lower Hella Fogs are mounted on Mid-Mount Lamp fixtures sold by Outmotoring.com I can think of slight modifications to these mounts to make attachment a bit more secure, like instead of washers behind the crush bumper use a bar connecting the top and bottom of the bracket.
http://www.outmotoring.com/mini-coop..._brackets.html
  #379
Old 07-22-2012, 07:46 PM
Minisnow's Avatar
Minisnow
Minisnow is offline
Sorry but I can't find a write up on how to change fog light bulbs, can someone help?
Ms
  #380
Old 12-23-2012, 06:21 PM
mona912's Avatar
mona912
mona912 is offline
How to replace front fog lights on MCS 2008?
Originally Posted by JimRoberts12
awsome
they look like they've got some blue in them? is that an optical illusion? i wanna stick strictly white.
Looks nice. Are they easy to replace yourself? The right side on mine just went off.
  #381
Old 12-23-2012, 09:25 PM
SMOG's Avatar
SMOG
SMOG is offline
Did you check the Outmotoring web site looking for instructions on bulb changes? I am pretty sure I saw an explanation on NAM as well.
  #382
Old 04-08-2014, 07:00 AM
actualsize37's Avatar
actualsize37
actualsize37 is offline
Reviving an old thread! Has anyone ever tried doing green fog lights??
If so, please enlighten me
07-16-2020 12:54 PM
08-21-2015 12:58 PM
08-19-2015 12:51 PM
I_drive_slow
08-18-2015 10:47 AM
Powershift
08-16-2015 05:14 PM
Quick Reply: Electrical Front fog lamp bulbs
