Electrical Front fog lamp bulbs
#101
on
Just an update, the 9 SMD modules seem to trigger the bulb out, but it's intermittent, i suspect it's because of the thin wires used for contact. I think bending them a little would increase surface contact. It's too dim anyways, so im giving them back and picking up a 13 SMD off ebay, like smoke05S posted and giving those a try.
#103
Ok since the city Hoen LEDs are not working out for me I need to find another option. I have the Hoen h8 xenonmatch fog lights that work great and match the headlights so now I need to find a city light with no problems that match the color and brightness of the headlights and fog lights as close as possible. I have been reading the previous posts about the 13 SMD LEDs and such, but am a little confused on what to buy. Could someone help me find the right city LED or post a link?
I bought these 13 smd LEDs for the city lights and they work perfect, no issues - they are closer to 6000K tho.
Hoen are waaaaaay overpriced btw....
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
here they are (courtesy of mr smoke)
#105
#106
LEDs are slightly more blue than my OEM HIDs....but still look worlds better than the orig yellow bulbs.
#108
Here is a shot of them under the Bridal Veil Falls at the Dragon this weekend.
Kevin
Florence, AL
#110
Hey Smoke05S,
I am not on much at all in a while. Most of my friends quit haming it several years ago and I have too. Since I moved a year ago I haven't even unpacked my radios.
I really like all of your LED stuff! I saw several LED interior lights at the Dragon and that is something I am going to start working on next. There is always something I need to buy for this MINI!
Kevin
Kevin
#111
I have been off the air for almost 3 years myself until the other night when 6 meters was open to your area. It appears to be a phenomenal season brewing.
Thanks for the LED compliment! I am learning as I go so I put all my mistakes out there so hopefully everyone can learn from them. I have a dome light and back up lights on the way to complete the project.
I truly am impressed by that picture. You should enter that one in a contest. It belongs in a calendar or a screen saver! Good work!
#112
on
my 13 SMD from ebay works great...no issues
there's also 25 SMD available...!!
http://shop.ebay.com/i.html?_nkw=194...286.m270.l1313
#113
#115
Kevin
#116
Is Ho-en Endurance really brighter than HIDs? I am about to buy HID kits(3000K) for fog light...The cost of Endurance seems high($39+shipping) while cheap HID kit costs about $40~$50. I don't care about bulb out error.
Do I need to go with Endurance? Endurance installation should be easier than HID kit installation. If the brightness of Endurance is about the same as HID, I will definitely go Endurance....
And there is Nokya halogen fog bulbs($20 at Ebay). Are they brighter than Ho-en?
I cannot decide^^
I cannot decide^^
#118
I wouldn't say the Hoen's are brighter than HID's but they sure are close to being equal IMO. They are extremely easy to put on (just be sure to read in earlier threads about squeezing the back of the connector).
I have no experience with the Nokya's so I can't comment on their brightness. I can say I was okay with the $39 after buying because they sure are a deeper brighter yellow than most other yellow fogs I see on other cars in the area.
#119
My friend sent me more 3 more sets of bulbs to try from his misadventures. DO NOT buy these, or the 12/24 SMDs that are out there. Basically, anything that has two of the small rectangular SMDs side by side. They won't clear your housing, because, while the circular chip is the correct diameter, the edges of the SMDs make it just wide enough so you can't insert it past the top layer.
#121
on
Here, i made a quick composite of the top down view and side view of the leds. It'll show why those side by side leds won't work.
On the Left, the side x side led module. The red arrow showing the portion that prevents it from clearing the housing. You'd have to shave down at least two corners for it to clear the housing, which i think would damage the led.
On the right, the 9-SMD module, see how nothing protrudes beyond the circular base. There isn't much clearance beyond that base.
#122
I just installed these today and for awhile no issues. Then i started getting the bulb out warning the 4th or 5th time I started my Mini . I mean its not that bad, but I would like to find an LED that does not give any bulb out warnings. I will probably have these installed until it gets too annoying. If there are not any LEDs that work then I will probably just bite the bullet and buy the 3,850 Hoen w5w city lights even though they are not as bright.
#123
#124
#125
The Hoen 3850 w5w city lights look almost orangish next to the xeon match fogs. I've been searching for a city light that is closer to the fogs for a while now. I'm more interested in matching the color more than getting really bright leds for the city lights. I've also tried the Philips BlueVision city lights, but they are almost identical to the Hoen.
