Electrical Front fog lamp bulbs
Old 01-24-2011, 10:05 AM
pheatton's Avatar
pheatton
pheatton is offline
I just picked up a set of the PIAA xtreme white wedge bulbs and a pair of Nokya Hyper Yellow H8 fog bulbs. Installed them this past weekend with my front/rear mudflaps. The PIAAs look great and from Amazon were very cheap.
After having the yellow fog bulbs in my GTI I had to have them back. In rain and snowy weather like we have been getting they are a great!
I went with normal bulbs so that I did not have to mess with resistors etc.
  #202
Old 01-31-2011, 03:30 PM
peter314's Avatar
peter314
peter314 is offline
Got my bulbs from Hoen today and just installed them, Took way longer than it should have but they were stubborn and didn't want to come out. Def unplug the wires first and then take the Fogs out first and the DRLs are so much easier, especially on the drivers side because of the tight confines of the coolant/wiper fluid tank.
The DRLs are still a little more yellow than I would like though.. I want them to be white white. Like the Xenonmatch fogs and the main beams. I avoided buying the LEDs because I heard they were problematic.
Looks like I'll have to keep looking for those.. Kinda sucks though.. $20 gone...
Pheatton, What lights did you get for the DRLs and how are they color wise? pics?
  #203
Old 01-31-2011, 03:35 PM
pheatton's Avatar
pheatton
pheatton is offline
I got the PIAA Xtreme white 194 for the little lights above the fogs in that same housing. I have xenons so I don't have anything in the main beam area other than the projector and turn signal.
I get some pics of what I have installed if you all want.
  #204
Old 01-31-2011, 05:17 PM
minimike21's Avatar
minimike21
minimike21 is offline
is 194 the same as w5w? im getting confused looking for nokya hyper yellows for the driving lights above the fogs...
  #205
Old 01-31-2011, 05:30 PM
pheatton's Avatar
pheatton
pheatton is offline
194 and w5w are basically the same thing.
194 is 4w and w5w are 5w. They are the same bulb connector.
  #206
Old 01-31-2011, 05:31 PM
minimike21's Avatar
minimike21
awesome! thanks for the info
  #207
Old 01-31-2011, 10:50 PM
smoke05S's Avatar
smoke05S
smoke05S is offline
I've been away for a while. But I can give you all a longevity report on my LED projects.
I am on my second set of ebay 13 SMD LED eyelids within a year. The first set blew a row on the drivers side making it a 9 SMD. That triggers a bulbout. So the 13 SMD's need to be working flawlessly to avoid the bulbout on their own, 26's don't fit so save your money. They make error free T10s now but not in 13SMD and heat eventually wipes the actual LED's out (so you end up with a bulb actually out and no warning!) For bulbs that are on continuously, be prepared to replace them yearly or go incandescent. This same eyelid LED mod on the 2010 JCW clubman doesn't work as nice as on the cooper. That car is very temperamental compared to the JCW cooper and it throws bulbouts with everything working. The bulbs move in the holder and go out all the time (never happens in the cooper). I went back to incandescent until I go HID retro then I'll do the silicon trick and the resistor trick. It took 4 tries to get plate LED's to work without a bulbout on the clubman. On the cooper the same plate LED's are working flawlessly after a year. It is easy to get a festoon style to work, tough to find a T10 so far for me at least. UPDATE Uncle! On the CLubman. Both plate lights out now, no bulbout. Bang on them and they come on and flicker off, all while there is no bulbout warning. The socket appears to be overheating too. I replaced them today with std 9 SMD T10, Way brighter, better color, no banging, reliable, Bulbout! I have been saving some resistors for this kind of project, time to use them I guess.
My turn signals still work on the cooper but I never could stop the bulbout. I put in incandescent turn-signals to go to the dealer for my service and that cleared all bulbouts. I would not recommend that mod even though visually it does everything I wanted (100% stealth, rapid rise and fall in brightness, a deeper amber color and they are brighter than stealth bulbs). My next mod is to go back to incandescent yellow bulb with a blue coating to go after that high end Range Rover look. Should look awesome on HZB.
I have LED back up lights now. Using ebay special bulbs at about $7.00 a set. This mod is a keeper. Looks cool and is very functional too. It's an 1156 bulb.
http://cgi.ebay.com/ebaymotors/2-x-C...Q5fAccessories
You have to use a 6 ohm 50 watt resistor on each side or the computer will not even send power to the lights. They are much brighter than the stock bulbs, have 68 elements and no bulbout. Because of intermittent usage they are going to last a long time.
All interior LEDs are working the same as when I installed them over a year ago. All bulbs on each project are listed somewhere in this thread or other recent LED threads. Anyone have pics of the Hoen xenon match eyelids in action? Would like to see the brightness and coloring. . . . I see below example looks really blue. Before I started all this I had some incandescent bulbs nearly that color and almost got a ticket.
  #208
Old 02-02-2011, 09:11 AM
peter314's Avatar
peter314
peter314 is offline
Some pics would be great of the PIAA DRL's installed and running. I really want to change the DRLs to a Xenon matching white.
  #209
Old 02-02-2011, 09:21 AM
peter314's Avatar
peter314
peter314 is offline
Also, Has anyone bought a set of Nokya H8 Hyper Yellows? I was just thinking about it and the Hoen Xenon match are useless in the winter so I am going to keep the W5W city lights (I think) and pair them with some Yellow Fogs in the winter and then Switch back to Xenon Match whites for the rest of the year.
  #210
Old 02-02-2011, 01:01 PM
pheatton's Avatar
pheatton
pheatton is offline
I have the Nokya H8 bulbs. I will have pics later tonight.
  #211
Old 02-02-2011, 04:45 PM
peter314's Avatar
peter314
peter314 is offline
Sweet, thanks
  #212
Old 02-02-2011, 05:33 PM
pheatton's Avatar
pheatton
pheatton is offline
OK first pic is the PIAA 194 bulbs.
Second is the Nokya Arctic Yellow bulbs.
  #213
Old 02-02-2011, 06:23 PM
minimike21's Avatar
minimike21
those looks fresh!!
  #214
Old 02-02-2011, 08:48 PM
peter314's Avatar
peter314
peter314 is offline
Thanks Pheatton,
dare I say though that the PIAA bulbs look Really blue and the Noyka's are actually more white than I would have thought... hmm interesting...
Going to try and return the Hoen City lights and maybe opt for a set of the Endurance yellows.
this is starting to become a very expensive project
  #215
Old 02-03-2011, 06:25 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Rally@StanceDesign is offline
Originally Posted by peter314
Thanks Pheatton,
Photo white balance is probably messing with the nokya yellows. They would never look that white.
  #216
Old 02-03-2011, 08:04 AM
peter314's Avatar
peter314
peter314 is offline
So then Its probably messing with the PIAA's too cause they look REALLY blue
  #217
Old 02-03-2011, 08:20 AM
minimike21's Avatar
minimike21
  #218
Old 02-03-2011, 10:51 AM
pheatton's Avatar
pheatton
pheatton is offline
Yeah they look very white in person and a bright yellow in person for the fogs. My phone my have a great camera in it but night shots suck on it.
  #219
Old 02-07-2011, 05:35 PM
minimike21's Avatar
minimike21
just ordered some nokya hyper yellow 194 bulbs for the driving lights... hopefully itll make my fogs look brighter now that i have both fog and driving lights with the nokya hyper yellow.
  #220
Old 02-14-2011, 05:12 PM
minimini482's Avatar
minimini482
minimini482 is offline
Originally Posted by minimini482
Does anyone have any pics of the Hoen W5W city lights (NON LEDs) installed on their MINI?
Any issues with the higher heat output from OEM bulbs?
Thanks.
Today was finally above freezing so I installed these Hoen city lights. I'm not thrilled with the results. They basically look just like the stock city lights. Compared to the factory HID headlights, they look yellow.
I asked Hoen to refund my money on these and I am contemplating just getting the LED city lights. $40 is pretty steep though...
This is a bummer.
  #221
Old 02-14-2011, 05:21 PM
pheatton's Avatar
pheatton
pheatton is offline
PIAA makes a very white and very yellow 194 bulb that can be used instead of an LED.
PIAA miniature bubls
  #222
Old 02-14-2011, 05:22 PM
scottab36's Avatar
scottab36
scottab36 is offline
Love the Hoens!!
  #223
Old 02-14-2011, 05:30 PM
minimini482
thanks pheatton!
the only type listed on that link are 168 wedge. Will these fit ok?
http://www.shopatron.com/products/pr...PIA19172/353.0
do you have any additional pictures of these PIAA bulbs on with your HIDs on as well?
  #224
Old 02-15-2011, 09:23 AM
pheatton's Avatar
pheatton
pheatton is offline
168 and 194 are basically the same bulb. I can get a pic of mine tonight since its back from the dealer.
  #225
Old 02-15-2011, 09:24 AM
minimini482
sweet thanks!
Quick Reply: Electrical Front fog lamp bulbs
